irab88's 1993 PickUp Build-Up Thread
#2561
Oof. It's been a while. Adult responsibilities took precedence, but I'm back at it:
This weekend's progress:
Was about to test fit the mounts, then realized they weren't painted, and probably wouldn't want to take them off once I had them mounted.
Primer, followed by some burgundy I wanted to try out.
Test-fit nicely, I purposely didn't paint the bottom because I knew I would have to weld under there. Once it's all done, more paint!
And finally, tacked in with the mig (FC) and fitted with all hardware (not tight yet).
I have a few washers for the bottom coming this week. I still have to do the driver's side, but now I know how to go about it. Cut the old mounts off, clean up, new mounts in, tack weld, new hardware. I don't have confidence in my abilities to TIG upside-down yet, so I may look for some outside help on that. For now, it'll support its own weight.
Damn I miss driving this thing.
The following 2 users liked this post by irab88:
Nervo19 (09-12-2021),
RAD4Runner (09-18-2021)
#2562
And on to yesterday's progress. I actually got everything done Friday that I planned to! That's a first!
As long as I'm working on my truck, no one can say NOTHIN' about the mess.
And old bolts out! Spent a good deal of time with the oscillation tool and HF-Dremel clone. The bolts spot-welded on the bottom were persuaded to vacate the area by Mr. Hammer and Mrs. Chisel, surprisingly easy.
The rear one had different nuts and bolts than the other 3; It had flanged hex nuts spot-welded in 3 places, as opposed to the others with square nuts tacked in 4 places.
Eh, I think I could get another 100k out of these bad boys...
I'm not doing the front mounts due to how they're a hair different, and they aren't taking a brunt of the weight. I did want to change out the hardware, and found out that the 7/16-20 grade-8 bolts I already had fit nicely. A 7/16-20 x 5" would be perfect for a 2" lift, but I ordered 6" and 4" for the main mounts. So I'll see if I can get the 6" to work for now.
Maybe this weekend (doubt it, but we'll see) I can get this side tacked in. That'll be some good progress.
#2563
Both sides got tacked in and torqued this weekend. Engine is back together and front back on. Today I'm stopping by to get a new battery (old one went to the celica) and finishing a few last things. The goal is to drive it before the weekend.
pictures soon
pictures soon
The following users liked this post:
RBX (10-20-2021)
RBX (10-21-2021)
#2567
Brake light is connected to the parking brake and brake fluid level circuit. Either a switch is bad on the park brake or you’re low on fluid. Not sure if the light will stay on if you have a wiring issue, or something not plugged in.
#2568
Not much on the truck in a while. It's still driving fine, and even helping with a move. I need new tires, and I think I'll be going 31's or 30's. Other than that, the goal is to get it more reliable. I have the steering all squared away, now I'd like to lower it a little and clean it up.
however
I've taken on a new muse:
1937 SS100 Jaguar modified replica
Build will be happening here:
https://regolith100.blogspot.com/
however
#2569
however
however
sdstud212001
04-01-2006 12:57 PM
