help! i cant get the cam bolts out of my 1994 yota pickup 4x4
Old 08-14-2011, 09:02 AM
pgabe944's Avatar
Exclamation help! i cant get the cam bolts out of my 1994 yota pickup 4x4
hey i am piting a 4-5" suspension lift in my 94 yota can i cant for the life of me get the blots out of the lower control arm.
Old 08-14-2011, 03:12 PM
eric924run's Avatar
Yes the tightest bolt on the truck i believe. my 1/2 ir super gun wont even touch it. it wil pull the crank bolt tho. What ive done is use a large chain wrench. i then wrap an old t belt around the cam gear. cut the belt to wrap around the gear once. then put the chain wrench around the gear. The belt prevents gear damage. get a piece of pipe that will fit around the chain wrench handle. the pipe i have is like 3ft long. then put your breaker bar on the bolt. i use a pipe on the breaker bar also. even with this it can still require lots of effort.
matrad
01-04-2019 03:06 PM
rondogracing
25
12-11-2015 07:26 AM
duckhead
07-17-2015 04:45 AM
Yota.Jay
07-02-2015 12:57 PM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: help! i cant get the cam bolts out of my 1994 yota pickup 4x4
