Gevo's 91 4Runner Build Thread
#61
OK... so I'm looking ahead to order various seals, gaskets, parts.. etc.. so I can do all of these things while the engine is out. I started looking at my power steering system which has leaks everywhere and the steering has a lot of play. I'm getting the following items new.
-Steering Damper
-All new hoses (the pressure lines are pricey!)
-Rebuilt steering pump (do you recommend rebuilding myself? I read the writeups threads on here...?
-Steering Gear (OEM cost $2k+... lol!!)
My question tonight is with the steering gear.. the rebuild kit cost either $25 or $52 bucks.. and I couldn't find a yotatech build thread.. A rebuilt one is around $200.. anyone have strong suggestions on rebuilding myself??? the fsm has a decent section on it..
PS: Personal problem.. autozone/pepboys/napa/oreily NONE of them stock a pulley holder tool.. !!!!
-Steering Damper
Or Northern Tool: http://www.northerntool.com/shop/too...4176_200354176
Also, any standard puller set should have a puller that would work based upon what HF's selling, but not sure if that's what you need...
#62
RSR, I have a puller, I need the holder tool... But, alas, I realized i don't need to do that part at all, I can leave it to the rebuild mechanic
My friend and I had a very fun time taking the steering arm off of the steering gear, the pulley puller helped out there
OK! SO.. gonna share some of my experiences thus far... I started cleaning the various components.. Started with the throttle body... There was sand in one of the low pressure fuel lines (i'm pretty sure they are fuel lines.. can barely remember) and all sorts of weird stuff in the little routes through the throttle body. I came across this little mechanical pressure valve deal.. Haven't had time to look in the FSM to see what exactly this is.. but this was full of sand when I took the cover off..
Here is it after i cleaned it.. now I have to figure out how far the screw should be tightened down :/
Here are the three simple components.
If anyone knows of a cleaning kit I can use for all of these components it would be great.. I am about to take out my shotgun cleaning kit...
RSR or Gamefreak, you guys mentioned amsoil cleaner, but that was with the parts on.. is there something similar I can use as a bath solution that would breakup the crap on the metal and not damage the part? I would generally use simple green, but that is not gonna cut it for this.
OH, and here is my buddy after we took off the engine harness.. he's gonna refurb it for me
#63
For cleaning you could probably get a small Rubbermaid tub and some mineral spirits and clean it and whatever else in that. It will take off almost anything and it's pretty gentle. Use it at my buddy's shop he has it in a wash basin that has a squirt hose and brush in it and clean my dirt bike parts in it.
#64
So, is this the solvent you're talking about? I've never used this kind of stuff before.. I assume it doesn't etch aluminum?
http://www.walmart.com/ip/Klean-Stri...ingMethod=p13n
#67
"Mineral Spirits" and Paint thinner are essentially the same thing. It will dissolve most greases (but not carbon buildup), so it would be good for that job.
The problem is disposal; what are you going to do with a tub full of toxic waste? Can't pour it down the drain. But if you're using it a cup at a time, you can just save it (the dirt will settle out, just like in a commercial "parts washer"). Don't use an open container to store it; it is flammable.
But for something big, I suggest a strong solution of dishwasher detergent. Let it sit overnight. Rinse with plain water. It can go down the drain.
#68
Yes, it is that easy. If it's strong enough a day or two soak will make the grime just fall off. Also good to do on the air chamber and the intake manifold if you're taking it off. Might need a little bit of scrubbing though so buy yourself a water bottle brush or some steel wool.
#71
Thought I'd share.
So looking at the head - lower intake - injector setup , I think that the orange's flow patter is likely best. It appears to be an inch or less between injector tip and valve/chamber. (Bearing in mind the injector tips on flamethrower look to be ~2x as long as stock)
Top view of lower intake:
Bottom view of lower intake:
Top view of drivers side head (it sits at an angle so this edge is roughly flat/horizontal against intake manifold):
Considering the spray pattern and location, it looks like the orange will send spray to/around edges of intake valve (not sure of exact angle of injector to intake valve, but even if aimed at edge rather than center of intake valve) the orange spray should be sufficient (worst case it's a finer mist for the intake air to keep it from bouncing off surfaces and instead pull it into the intake) -- and if anything, I'd presume the orange spray is slightly superior to gray for the 3vze...
Here's the youtube on the orange:
And the black Bosch:
#72
Thanks for sharing.. I did a bunch of reading here and elsewhere and decided to go with the orange flamers... ordered them.. we'll see what happens
Also.. next deal, new radiator.. I am getting a separate tran oil cooler.. and i want a VERY good and large radiator... i came across this.. only has 1 year warranty (some cheaper ones have lifetime?) and it's not cheap.. 6061 Au looks nice
what do you guys htink? is it worth the extra 70 bucks over cheaper radiators? (also 3 rows)...?
http://www.ebay.com/itm/3-ROWS-CORES-1988-95-TOYOTA-PICKUP-4Runner-3-0-V6-RACING-ALUMINUM-RADIATOR-/221290499915?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1991%7CModel%3A4Runner&hash=item3385f10f4b&vxp=mtr
#73
3 Rows Cores 1988 95 Toyota Pickup 4Runner 3 0 V6 Racing Aluminum Radiator | eBay
And others sell the CC50 for similar prices on ebay, so it again it might be the same item or you could pay a little more for the item with a better known pedigree: http://www.ebay.com/itm/3-Row-Radiat...-/130883384882
Here's the CC page: http://www.championcooling.com/produ...inum-radiator/
Good threads on 3vze radiators: https://www.yotatech.com/forums/f116...y-3vze-248174/
http://www.toyota-4runner.org/classi...ay-speeds.html
#74
Alright, thanks RSR.. i also did some more research about the various core sizes and such.. this one I linked earlier seems like a pretty good one. As long as the aluminum welding is good quality, this is a great radiator
now, to share one of a tools I've had to buy to do this engine removal... I got it for $125, it's practically brand new... I love it.. unfortunately it's huge.. I'm gonna sell it after I install the engine
#75
GUYS.. I need some aid... I am trying to find the gasket depicted in the following image as
35182.
This is from toyotapartsoverstock.
The problem is that in a better OEM parts site which has no image) tha ti actually order from it says it's not compatible with my car. This site uses my VIN to check. I have the 340H tranny.. I want this gasket.. any ideas?
35182.
#76
35182.
35182.
Only an A340E application I believe.
Maybe 34152 for the a340h here is what you're looking for? It's named "RECEIVER, TRANSFER CHAIN OIL" but appears to be an oil seal or gasket. I suppose you could order at your local parts counter and return it if it's not what you think it is (dealer near me allows this, though their prices are often 2 to 3x the cost of internet dealers; I find going there however results in them ordering the wrong parts at least twice unless I go in with part numbers, in which case considering time and gas, I'm ahead to order online [so I only order there when the graphs suck and I don't want to bother w/ an internet return...]).
http://www.toyotapartsoverstock.com/...rimLevel=18292
#77
RSR,
I need the other one that mate the surfaces of the extension housing to the transmission. The one you listed is for the chain case. I need that one to of course
I guess I can try to get the part number from the dealer. There goes 2 hours of my time :/
On the upside, my flamethrowers and B&M tranny cooler arrived yesterday
#80
I just wanted to share my progress.. albeit slow I admit, but I can only work on it on the weekends!
Sat, got the engine out... that was an adventure on an inclined driveway.. lots of problem solving
That's my good buddy concentrating. lol.
I'm taking it to the machine shop this afternoon. I really hope they don't make any mistakes....
I also spent many hours cleaning the rest of the parts... I didn't get far. I think i'm going to see if this engine shop, or another, will clean them for me. (I want everything sparkling shiny clean when I put it back together... ) I will spend my time cleaning the rest of the insides of the hood.. it's a mess.
ok. so far, so good. Again, I wouldn't be as confident as I am without having read everyones experiences and advice on these forums... always grateful!
