Gennro's turbo 22re, standalone build-up!
Old 05-04-2012, 05:27 AM
rattlewagon's Avatar
Cool build man. Nice work on that manifold!
Old 05-04-2012, 06:39 AM
Doitzel_Kaiser's Avatar
Nice! Very Grassroots!
Old 05-05-2012, 10:19 AM
gennro's Avatar
Should be starting the engine today! Stay tuned......
Old 05-07-2012, 09:16 AM
gennro's Avatar
Well a little update. The coilpacks I got are complete crap, engine will kinda run, not well though. Ordered a new coil pack from rockauto. Everything else is mostly done though, gotta tiddy up some wiring. Also finish up the exhaust.
Once it get it running well I will post a video and some more pictures.
Old 05-08-2012, 09:50 AM
  #25
gennro's Avatar
Well I had a dumb moment for today. Found out you need to have the coils wired in series instead of parrell for them to work with EDIS4. Which means the coil packs are not getting fully charged in which is causing the very weak spark. Today the startup video will be posted.
Old 05-08-2012, 06:01 PM
  #26
gennro's Avatar
Who likes videos!!!!!!!!!!!!!!!!!
Well that only took less then 2 weeks to do. Just have to finish a few things up and will be all done!
Old 05-08-2012, 07:12 PM
  #27
snobdds's Avatar
Nicely done. I like how you, from the start went with the stand alone ECU and the mega squirt. Trying to figure out the stock toyota re"t" ECU and adapt it into the system would be too big of a pain. I would like to know more about how you got everything wired up, for example the cold star injector time switch, and other various sensors.
Old 05-08-2012, 07:22 PM
  #28
gennro's Avatar
The cold start stuff is no longer required due to the microsquirt being way newer. Only used the stock coolent sensor and TPS. Thats it.
This write-up made it real easy to do also. http://www.diyautotune.com/tech_arti...oyota_22re.htm
Old 05-09-2012, 06:32 PM
  #29
gennro's Avatar
Well did some more tuning today. Fixed another exhaust leak in the manifold gasket. All I have to say this was well worth it. Running 4psi with this turbo. Pressure is almost instant. Will roast the 31's with no problems. I would say it pulls much harder then a 5VZ.
Old 05-11-2012, 06:05 PM
  #30
gennro's Avatar
Well did the new coil pack and wires. Adjusted the valve lash, changed the oil to Rotella T6 5w-40. Did a lot more tuning. Engine runs great with 6psi.
Old 05-11-2012, 06:49 PM
  #31
ToyoTech559's Avatar
wow. that is nice!!
Old 05-18-2012, 08:29 AM
  #32
bobbybouche's Avatar
Very cool build Gennro, nice job.
Old 08-27-2012, 03:56 PM
  #33
mica's Avatar
Subscribed
Old 08-27-2012, 03:58 PM
  #34
mica's Avatar
Could you post up some better photos of the intercooler setup?
Old 01-20-2013, 05:47 PM
  #35
Rollz79's Avatar
where did you get the piping for the EX mani?
Old 01-20-2013, 05:54 PM
  #36
justin smith's Avatar
Sweet
Old 05-26-2013, 02:22 PM
  #37
gennro's Avatar
Still running fine btw....
Just sent some money to wabfab for some bumpers and stuff. Also have some 4.88 gears on the way and aussie locker for the front. Stay tuned.
New paint btw.
Attached Thumbnails Gennro's turbo 22re, standalone build-up!-2013-05-27-08.43.09.jpg
Old 05-27-2013, 11:11 AM
  #38
gennro's Avatar
Going to be rebuilding the rear drums. Wheel cylinder decided to start leaking while I was out in the mountains yesterday. So ordered new shoes, wheel cylinders and hardware.
Old 05-27-2013, 01:53 PM
  #39
Orion22rte's Avatar
How does the 261c cam work with the turbo? I'd imagine it'd be awesome down low with the small turbo. But can you tell me what the power is like? Cuz I was gonna go with the 268 and not sure if it would even make a huge difference. But I haven't seen anyone with that setup. Thanks and great work!
Old 05-27-2013, 06:24 PM
  #40
gennro's Avatar
Works great, lots of low end, but mind you I am on a standalone.
Quick Reply: Gennro's turbo 22re, standalone build-up!
