Dub Tek's 1991 Regular Cab > Build Thread
Old 12-14-2011, 02:48 PM
  #41
dub tek's Avatar
Just finished installing THIS STEERING STABILIZER from summit racing...
Was a direct fit
No brackets and such
MUCH LESS feedback in the steering wheel then prior
Now its time to start shopping for the arm on the pass front frame rail
Its sloppy in the bushings
I have seen replacements from many spots
http://www.roughtrax4x4.com/ seams to have good stuff
But the overseas is killing any good chance of shipping
Old 12-14-2011, 03:00 PM
  #42
dub tek's Avatar
Im also shopping amsoil fluid
Ill have a full part # AND quantity list soon > PAT
Old 12-14-2011, 04:27 PM
  #43
engineshoppa's Avatar
Should look at 235/85r16's tires. Tall and narrow. works out to be 9.25 x 32 on 7 inch wide rims. I used chevy 16's mags off of a newer 1500 and machined the inner bore to fit locking hubs. before that I used steel wheels cut in the center with good hole saw. Good luck with the truck.
Old 12-14-2011, 06:01 PM
  #44
toastyjosh's Avatar
Here is a link to all the BFG AT tire sizes
http://www.tirerack.com/tires/tires....rrain+T%2FA+KO
They do make a 33x9.50! Only a inch taller!!!
http://www.tirerack.com/tires/tires....l=Grabber+AT+2
http://www.tirerack.com/tires/tires....dar+M%2FT+Plus
Old 12-14-2011, 06:06 PM
  #45
toastyjosh's Avatar
poly bushings
http://www.suspensionconnection.com/...tion/to=r.html
Old 12-17-2011, 01:28 PM
  #46
dub tek's Avatar
Originally Posted by toastyjosh
Yes Im thinking the 33/9.50R15
To make it fly im also looking into OME front torsion bars
Along with there rear leaf springs
NOT looking for crazy lift
I drive it too much road for major lift
Im just looking for the FRONT sway bar bushings to frame rail bushings
Old 12-17-2011, 01:31 PM
  #47
dub tek's Avatar
I just finished the timing chain install
Along with modifying my OE "updated" thermostat to totally eliminate the overshoot.....
Also scored some SR5 interior trim at pull a part
Ill be adding the the carpet + plastic trim behind the front seat/under the rear window...
Old 12-18-2011, 05:22 AM
  #48
dub tek's Avatar
Chain Day was a learning experience
VERY easy to do these kits
Id say about 2 hrs work total now that i know the layout .......
-TeK
Old 12-18-2011, 05:25 AM
  #49
dub tek's Avatar
^^^ CB mounted direct threw the cab ^^^
^^^ The steering stabilizer from summit ^^^
^^^ SR5 Rear cab carpet liner ^^^
Ill be adding the "B"pillars once I drill the holes
Old 12-18-2011, 05:44 AM
  #50
dub tek's Avatar
Little AIR VENT for the foot wells up front
Im allways cold so these are a score in my book!!!!
The vent goes behind the lowest cover and under the steering column
It requires a bit o dremell tool on my end as I do not have the proper lower cover from the sr5 truck that has the vent
Ill have pics of this as well...
Old 12-18-2011, 05:48 AM
  #51
dub tek's Avatar
Also scored the lowest center console cover
This version is again an SR5 part
It has the extra little storage compartment
Old 12-18-2011, 06:24 AM
  #52
dub tek's Avatar
I have also shopping exhaust parts
LINKS TO 02 sensor flanges below::::
OXYGEN SENSOR FLANGE <Conventional Toyota Sensor
OXYGEN SENSOR FLANGE > Conversion << Converts toyota flange to typical externally threaded 02 sensor
Looking for the following::::
"Y" pipe flange < It bolts to the Stock Manifold Dual Outlet
The front flange on the pipe in THIS LINK < Link has "Y" pipe..
I just need the flange
Old 12-18-2011, 06:47 AM
  #53
dub tek's Avatar
COPPER Header Gasket < Looking into this as i have seen MANY of the paper versions blowing out... The fire ring of metal inside rusts out causing gasket failure
Old 12-19-2011, 06:30 PM
  #54
PATDABIN's Avatar
Found the o2 Sensor bung for you. Swap over to the screw in kind!!
http://www.rockauto.com/catalog/moreinfo.php?pk=3425949
Old 12-20-2011, 03:38 PM
  #55
dub tek's Avatar
DO everyone a favor..... "PATRICK"
READ before you post
This is linked in previous reply
This post is directed at a local ass hat that I know of....
Old 12-20-2011, 04:51 PM
  #56
dub tek's Avatar
I added the carpet that covers the rear of the cab inside from an SR5
Also added the plastic trim strip below the rear winder and holds the top of the carpet in place....
Old 12-20-2011, 04:57 PM
  #57
dub tek's Avatar
CB mounted in Center Console
Just need to trim that panel at the top of the page to fit around it
Old 12-20-2011, 05:05 PM
  #58
dub tek's Avatar
I Painted the aluminum rear window trim
^^^^ SILVER WINDOW TRIM
^^^ Half assed prep
>>>For my BS paint job.
^^^ Painted
Old 12-21-2011, 04:53 PM
  #59
dub tek's Avatar
Amsoil:
Front + Rear Differential Oil
Transmission + Transfer Case Oil
Old 12-23-2011, 02:49 AM
  #60
dub tek's Avatar
Got my drain + fill finished up
Front Diff fluid was DIESEL Engine oil BLACK
Transmission fluid was very light yellow... LOOKN GOOD!!!
Transfer Case fluid was very light yellow... LOOKN GOOD!!!
Rear Diff fluid was....... Well.... It looked like thinned out and Burnt peanut butter
Ill be doing the differentials AGAIN soon... 1000 miles-ish
Id like to throw in some BS oil quick as a "rinse" ... but we shall see
I assume this is due to NOT having a diff breather extension and taking in water
Quick Reply: Dub Tek's 1991 Regular Cab > Build Thread
