Cr@ves4wheelin 1990 Hilux Build Up Thread
Old 01-05-2014, 07:22 PM
  #41
cr@ves4wheelin's Avatar
Worked on getting the upper balljoints out of the knuckles. Easier when its still in the truck, but I somehow got lucky.
'Sides that I got the cross shafts out of the UCA. Pretty easy to do, easier than the LCA experience I just had. Credit goes to Blazen8 though, as he posted a way to do it on another build thread on here. I read it a while back, but forgot to save it. Spent 30 mins tryin to find it lol.
I don't own a vice, so I used the quad to hold down the UCA. The end of the shafts are "slotted"? The nut on each side has a dimple to prevent the nut from backing off the cross shaft. So you gotta straighten them out before attempting to loosen them.
Attachment 144849
After both nuts on each end are off, take a C-clamp and use that to press the cross shaft out. **NOTE:ON THE TORSION BAR SIDE.** The bushing on the smaller end will push out but the torsion bar side bushing will remain inside.
Attachment 144851
Attachment 144852
When I was cleanin them up, I noticed a Katakana symbol on them. I know the symbol is read as "hi" (pronounced as "he" in English), but I didn't know what the symbol was supposed to stand for. I could ask my mom (who is japanese) later on, but I looked it up on google. It translated it to something as arsenate or arsenic? Wish I was bilingual, too bad it wasn't really a big deal back when I was a kid.
Attachment 144853
Anyways, I painted them with a hammer finish paint. Used the heater since it bout -30 degrees out with the wind chill factor. Makes me miss California a little bit.
Attachment 144854
Attachment 144855
Old 02-17-2014, 09:23 PM
  #42
Ordered a New Factory Fuel Pump Bracket and also, i got what the guy said to be a denso fuel pump from Napa auto parts. Was kinda pissed when I opened the box and compared with the old pump. But I'll give it a chance, and if it's crap, I'll have more right to be pissed off. Supposedly, it's more efficient than than factory.
I cleaned up the old fuel sending unit with liquid wrench to kill the rust and went over lightly it with sand paper.
Attachment 141899
Cleaned up the front diff a little bit as well, and did the band clamp mod to it.
Attachment 141900
Attachment 141901
Attachment 141902
Cell phone camera got weird in this pic
Attachment 141903
Cleaned up the frame rails for the shock hoops, so it's ready when I get my welder. Which should come at the end of the week or so. Also cut part of the old shock towers which is required for install.
Before:
Attachment 141904
After:
Attachment 141905
Then I wanted to get myself a little inspiration, so I went ahead and put the lower control arms in early lol.
Attachment 141906
Attachment 141907
Attachment 141908
Took off the hood and started on disconnecting stuff going to the engine. I also got an engine hoist coming soon.
Attachment 141909
Two things I want to share:
The AFM on the 3.0, the plug does come out. I've always heard bad stories with the circuit boards connections separating from the plug assembly. So I always had set the whole air intake aside in the past without unplugging it. Turns out, all you do is remove the metal clip on the plug and you can disconnect it. I guess some people had removed the screws and ended up ripping the connections. I uncovered the cap just to make sure when I did it lol.
Attachment 141910
Also, the camber bolts, adjustment washer, and nuts for the lower control arms. Got em for cheap at Village Toyota, I mean like <$100 or so for a whole set. They have a good parts source for just about all the little things.
For factory stuff, I usually go to olathe toyota parts website, or village toyotas parts website.
Old 02-17-2014, 09:50 PM
  #43
And just food for thought on interior/exterior cage ideas. But this won't be till probably next winter.
Attachment 141898
Old 02-23-2014, 10:16 PM
  #44
Had to get a new Gas tank cause the fuel pump bracket didn't fit the aftermarket one I bought. So I went ahead and bought a factory tank, saved a headache, but not my wallet. But I'm happy though, cause it has a lot better insides than the aftermarket did, and a drain plug.
Attachment 141559
The aftermarket tank did not have this pipe going into the tub.
Attachment 141560
Fuel Pump
Attachment 141561
Aftermarket tank did not have this splash guard in the filler.
Attachment 141562
Plainted over the bolts, connectors, and pipe fittings to try and prevent future rust.
Attachment 141563
Got the bed back on after that.
Attachment 141564
Attachment 141565
Attachment 141566
For the TC Uppers, I had to reuse the factory sleeve on the torsion bar side of the old arm. So I went ahead and drilled out the bushing, cleaned up the sleeve, grease and put it all together. Then I got all excited and mounted them.
Attachment 141567
Drill with wire wheel attachment
Attachment 141568
Sleeve put into new poly bushings
Attachment 141569
And boom goes the dynamite lol.
Attachment 141570
Attachment 141571
Old 02-24-2014, 04:42 AM
  #45
CamTom12's Avatar
Looks great!
Old 02-25-2014, 08:19 PM
  #46
Thanks bud
Old 02-27-2014, 02:48 AM
  #47
Cruz muench's Avatar
What truck would be the best restore. I think I'll get it from down south. Cause winters here really take its toll on older trucks.
Old 02-27-2014, 05:28 PM
  #48
I know what ya mean. Any truck is good to restore to be honest, just depends on how much you like that truck. Hell, there was a '66 toyota stout in Wyoming on craigslist for $800. If I didn't buy that $500 gas tank, I would have called him in a heart beat. Those trucks are way too rare and cool to pass up. Just ask yourself what you want to do, and what generation truck you like best with whatever it's got, ie solid axle and carb'd, or ifs with efi.
Old 02-27-2014, 05:37 PM
  #49
jaretstuff's Avatar
Sweet truck can't wait to see it done! I had a question though what makes this a Hilux and not just a pickup?
Old 02-27-2014, 09:03 PM
  #50
We call it the Pickup here in the US, but in Japan it was called the Hilux. I call it a Hilux because I refer to trucks as pickups in general and I'd rather call it by a model name. Don't go to the parts store saying Hilux though, they'll think your trucks RHD and a diesel or something lol. 4Runners are called the Hilux Surf in other countries. Nowadays we have Tacomas, but in different parts of the world the Hilux name is still going as it's own truck model line.
Attachment 141329
Attachment 141330
Attachment 141331
Attachment 141332
Attachment 141333
Old 03-06-2014, 07:02 PM
  #51
Guess I really don't need to say anything here...
Attachment 140808
Got my welder too, compact and works off of 120, but with the specs I asked for she'll get the job done.
Old 03-17-2014, 05:24 PM
  #52
A lots happened this past couple weeks. But yesterday, I sat in front of the truck, and I thought to myself, "You know what, I'm gonna yank this engine out today". Never thought I'd see my own engine bay empty, but man after looking at just photos and seein it in front of you in real life, it really meant a lot.
Attachment 140136
My engine stand didn't come yet, so I put in a milk crate lol.
Attachment 140137
Old 03-23-2014, 09:46 PM
  #53
Figured it was time to make things cleaner.
Attachment 139489
Not sure why the brakes and power steering are together in this one unit, or even how it works. Never seen one before, but I kinda hate it already. Plus it's in the way for shock hoops. So I threw it away lol.
Attachment 139490
Attachment 139491
The wiring actually got me, I thought everything was connected, but while I was taking everything out, I noticed that it was seperate from the fuse box. After that, I kinda made sense of everything.
Attachment 139492
So I yanked the grommet outta the firewall.
Attachment 139493
Unplugged the 3 connectors to the ecu (which is held on by 3 bolts btw), and then the 2 connectors.
Attachment 139494
Attachment 139495
Attachment 139496
More removal of stuff I don't need, ignition coil, cruise control actuator, etc.
Attachment 139497
Best it's gonna get for now.
Attachment 139498
Some custom bodywork lol for shock hoops, and overall just better accessibility. Anything to make a repair easier in the future.
Attachment 139499
Attachment 139500
Attachment 139501
Old 04-07-2014, 06:43 PM
  #54
Wire-wheel'd the engine bay, and painted.
Attachment 138106
Attachment 138107
Attachment 138108
Attachment 138109
Cleaned up the inside of the bellhousing
Attachment 138110
Got my coilover shock the other day too, so now I can mock up and weld my shock hoops as soon as I get shielding gas for my mig welder.
Attachment 138111
My engine stand came too, so I gotta get that, and the 3.4 block should be coming, gotta check and see what's goin on with that.
In the mean time, I started takin apart the front rotors and hub assembly.
Socket from wab fab was awesome, just used a flat head to flatten out star washer holding the large nut tight.
Attachment 138112
Slightly tap the whole assembly on the ground, and bearing should fall out.
Attachment 138113
Backing plate bolts, 12mm.
Attachment 138114
This part, you take out the 13mm bolts, and I used a large flat head, then a chisel, and then a crowbar to seperate the hub from the rotor.
Attachment 138115
Attachment 138116
Found this at Autozone, I couldn't help myself lol
Attachment 138117
That's bout it for now.
Old 04-07-2014, 07:23 PM
  #55
rattlewagon's Avatar
The freshly painted engine bay looks awesome! Nice work!
Old 04-07-2014, 09:00 PM
  #56
Mauk's Avatar
I like quick builds like this. not so much talking haha
good job man, looks great so far
Old 04-08-2014, 02:28 PM
  #57
chukarhunt's Avatar
That power steering/brake line box you didn't like and tore out, is for the ABS. The power steering powers that system, which in turn releases the brakes temporarily to gain traction. That's all.
Great build and looking great! Keep it up!
Old 04-08-2014, 06:29 PM
  #58
Thanks you guys, much appreciated.
Yeah I read up on that, I still don't know how the power steering powers it, but it's kinda cool in it's own way. It's nice that it's gone though lol.
I'm plannin on puttin 3 different security system on this eventually, gonna do the windows, and more than likely the paint myself. I'm gonna do my best to take advantage and do anything I was never able to do before with the old truck. To be honest, I already past the point where I lot of this stuff I'm doin is new to me, so I'm just tryin to go with the flow the best I can every Sunday.
Old 04-20-2014, 08:53 PM
  #59
Finally took a day off to go pick up a cylinder.
Attachment 137399
The new 3.4L block came last thursday.
Attachment 137400
Attachment 137401
Attachment 137402
Attachment 137403
Attachment 137404
I got one shock hoop fully welded on, the other side will have to wait next week. By the way, go easy on me about the welds lol. I've only had a flux core years ago, and have only taken one welding class for sh**s and giggles in college. The new mig welder is a little new to me, but I'm fortunate to even own one let alone all this other stuff lol.
In this pic below, I welded up the sides of the plate after I got the shock hoop done. I'll have more pic for you guys once the other side is done, and everything is painted.
Attachment 137405
Attachment 137406
Attachment 137407
Old 05-04-2014, 05:45 PM
  #60
Finally got the other shock hoop done, I ran out of wire and had to get another roll on Friday. I would have painted it black, but everything is coming to a halt. Need to step back a little and try to recover some money, because I'm somehow spending more than I make. Probably the all the alcohol and gasoline lol. Anyways, the 3.0L I put up for sale on craigslist, so if you're in the Wyoming area, wink wink nudge nudge.
Attachment 136378
Attachment 136379
Attachment 136380
Quick Reply: Cr@ves4wheelin 1990 Hilux Build Up Thread
