Cali '86 RTE 4Runner rebuild...
#41
Agree. Carpet does not belong on trucks that we use for their intended purpose. One doesn't even need a vacuum to clean vinyl.
I just use a counter brush (foxtail) for the vinyl cover in my cargo deck. Will replace the carpet with vinyl when I have the budget.
Best of luck with the build.
#43
LOL! I should've clarified that too, space-junk. Like the carpeted kick panels, I will keep the original carpet for future value purposes, should I choose to lay vinyl. It just needs a really deep-clean job. I have a fairly strong shop vacuum. When I dismantle May's interior for a complete once over, I'll put that vacuum to hard use. For the meantime, just like all of the other modifications listed above, I want/need items that are easier to work with.
I forgot to mention that I scored a used sand-blasting cabinet, compressor and hose for $80. I found it on CL about the same time I purchased May. I'm gonna sand-blast parts and repaint them.
#47
I just received my replacement OEM exhaust manifold. Thankfully, as advertised, it doesn't have any cracks. I'm going clean it up a bit. Perhaps by performing rust removal by electrolysis. I'll post the "after" photos when I get it done.
Turbo Exhaust Manifold (Bottom) Turbo Exhaust Manifold (Top) Turbo Exhaust Manifold (Side) Turbo Exhaust Manifold (Rear)
#48
interested to see how the rust removal via electrolysis works out!
as the attemptor of many home chemistry experiments, I am doubtful, but wiling to be proven wrong
try on scrap first and regulate your power supply!!
#49
I'm interested to see how it turns out too, magnet18. I'm going to test the electrolysis process on my cracked exhaust manifold before I even think of doing it to the one I just purchased and recieved. I'll do a write up and provide photos of my results when it's all said and done. I still need to gather the supplies. Wish me luck!
#50
Since I'm going to keep running the OEM automatic transmission, I'm going to want to run a transmission cooler equipped with a fan. I figure this will come in super handy especially when crawlin' or haulin'. I've been looking at this unit on Jeg's... Any thoughts or experiences with transmission coolers would be greatly appreciated. Thanks ahead of time.
#51
that looks mint! Where did you get it? I just bought one off ebay for $129.99 BIN. I had one for my '84 4runner way back when and decided it was worth it. Pretty heavy and awkward forreading at bedtime though!
#52
I use a $10 swap meet sand blasting hopper for lots of stuff. I'd think yours would do a good job on your turbo exh manifold.
Also a quick comment on the por 15 stuff. I used it on the underside of my Camaro and kind of wish i hadn't. Iirc, there is a cleaning chemical, then an etching chemical then the paint. I have recently seen lots of youtube videos on rust converters that you just paint over the surface rust. It starts out milky and turn everything black but functions as a primer if you want to paint over it. I think i will be trying this soon on my 4r's frame.
#53
POR15 works great, but it isn't magic and there's a lot more prep work than most people think. A lot of people think you just slap it on anything and you're good forever. Really you have to get to either bare metal or clean rust, if bare metal, you have to clean it and etch it to put a nice rust coating on it, then put the POR on really thin and time the subsequent coats right.
If you do all that, it's fantastic. But like any other paint, it's a lot more prep than painting
Sorry I have no input on transmission coolers, but I'm interested to see how it turns out, I'm thinking about one for my wife's mustang
#54
You can see how I installed it in my build thread at this link.. few posts from the top. https://www.yotatech.com/forums/f199...5/index13.html
And here is the link to the thread where I installed the B&M cooler... then made a cowling... then spent a lot of time thinking about it and still didn't work ... https://www.yotatech.com/forums/f116...08/index2.html
good luck
#55
Melrose 4r, I found the repair manual on eBay for $50. It is definitely nearly mint. It just has a few thumb prints from greasy digits and dog eared corners. I'm really considering on doing a full body off restoration so I can get to all of the surface rust spots. This manual will help a lot with that should I choose to do so.
And thanks for the tip on the Rug Dr. Carpet Cleaning Machine. I remember seeing those for rent at one of the local grocery stores.
I have vey high hopes for the sand blasting cabinet. There are a lot of goodies that could use some sand blasting. I'll do some before and after pictures of those projects too.
I had a feeling the POR-15 was going to involve a lot of prep work and different agents needed to complete the rust treatment. Can you PM me the link to the other rust treatments you saw on Youtube?
__________________________________________________ ________________________
magnet18, if I can't find a decent way to remove the surface rust, I might have to take it down to bare metal. I'll know for sure when/if I decide to pull the body off.
Gevo, I was looking at the Hayden ones too. I gotta do some more research before I decide on which one I'll end up installing. I should crawl under May soon and look up her skirt to find where I can possibly install a transmission cooler.
#56
Melrose 4r, I found the repair manual on eBay for $50. ...
And thanks for the tip on the Rug Dr. Carpet Cleaning Machine. ...
I had a feeling the POR-15 was going to involve a lot of prep work and different agents needed to complete the rust treatment. ...
Re: Carpet, I just removed mine and threw it in a front-loading washing machine. Worked well. On upholstery, I applied Febreeze until moist, scrubbed and immediately followed with a shop vac. Smells good now.
Yes, POR requires a degreasing step, then a metal prep step which leaves what looks like thin white lightly-oxidized, textured surface. The starter kit includes the necessary chemicals.
If repainting, best to get most of the rust off, and leave no loose rust. I tried steel brush wheel but it did not remove some loose rust. Instead, it gave rust surface a sheen that you could mistake for hard metal but is not. Better to use an abrasive wheel. The one with what looks like nylon bristles coated with abrasives worked well for me.
#57
RAD4Runner, that is a great idea! A front loading washing machine at the laundromat!
I have yet to completely see what I'm up against. I'll get a better idea when I crawl under her. I'll take photos if there are any notable items to point out.
#58
I had a feeling the POR-15 was going to involve a lot of prep work and different agents needed to complete the rust treatment. Can you PM me the link to the other rust treatments you saw on youtube?
#59
WOW!!! I am super impressed!!!
Melrose 4r, you are the man! Thanks for sharing that video, I'm going to order a few gallons for May and future projects!
#60
glad to help but please realize this is not a ringing endorsement because i have not tried it myself yet. Give me couple weeks and i'll report back.
