BuzzardsGottaEat 1993 Pickup
#83
#84
how well do your wind deflectors work? I have been thinking about getting some, but will probably have to wait until fall when it starts cooling down again, it's getting up to the high 90's low 100's now.
#85
Might I recommend WeatherTech ones that slide into the window crevasse rather than some cheapo stick on kind. Fixed my rattly window with the added thickness too haha two birds with one stone, as they say.
#86
Here is what I'm working on right now:
Here's the plan to get my 2006 XT225 up and running again:
Stage 1:
New battery
42.5 pilot jet
130 main jet
Idle jet screw 2.5 turns out
Shim jet needle with 1mm washer
Adjust air screw
UNI air filter
Flush fluids
Clean carb
Grease chain
Stage2:
Front sprocket 16t
Wider foot pegs
Hand guards
Rear rack
Trim front fender 4”
Handlebars or spacer
Stage 3: (Not definite, still need to choose tires)
Rear 18x2.15” wheel laced to front hub
130/80x18 rear (26.19”x5.12”)
110/90x18 front (25.80”x4.33”)
Any suggestions are welcome and appreciated!
Stage 1:
New battery
42.5 pilot jet
130 main jet
Adjust air screw
UNI air filter
Flush fluids
Clean carb
Grease chain
Stage2:
Front sprocket 16t
Wider foot pegs
Hand guards
Rear rack
#88
#92
I've already photoshopped it and completely plan on painting all chrome gunmetal haha things that are functional just take precedence over the aesthetic. Gotta mod the bike and finish my projector retrofit for the truck at the minimum. Then MAYBE I'll worry about looks over function haha but not likely, I have a long To Do List . . .
#96
Close enough. I thought maybe you still had the one where the lower valence was still black but they get the picture haha I'll definitely be painting all the chrome, it's just a matter of other priorities take precedence.
#100
Yeah, I'm north east of them. Someday I want to drive through the Black Hills, through Yellowstone and the Grand Tetons and down into Utah to Moab, Arches, and finally to Zion National Park . . . and then all the way back.
