Andersej: 1993 2nd Gen 4runner
Old 06-08-2014, 09:56 AM
andersej's Avatar
Got my Blazland kit in. Overall the istallation was a breeze and the quality of the product is very nice.
Got some stock t100 axles and some bilstein 5500's
Took off the wheel and hub.
Loosened the torsion bar adjuster nut, then removed it.
Unbolted the torsion bar from the upper A arm
Unbolted the upper ball joint then then unbolted the upper A arm.
Removed the Shock and unbolted the CV axle from the diff
After removing the brakeline and the tie rod I unbolted the lower ball joint and removed the knuckle.
Then removed the lower A arm.
Decided to replace all my Ball joints while I was in there so i just pickle forked the existing ones off.
Then it was time for reassembly! started with the Extended lower A arm.
Tie rod extension
Extended upper A arm
along with the torsion bar
New upper balljoint attached to Upper A arm
Extended Lower A arm and braided brake line
Put the new lower balljoint on the knuckle and installed. Had the raise the lower A arm quite a bit to line up the upper balljoint lol.
Before we tightened the lower ball join we installed the T100 CV axle.
Ataached tierod to knuckle.
Installed the shock (which the first time we had to man handle it in because we didn't install it before tightening down the lower ball joint.)
Lookin good.
Install the spacer and c clip then reassemble the hub and smack that tire back on!
Rinse and repeat with the other side and voila! There was probably 2-3in of more travel available still.
I am only going to run this set up for a couple months to save for the coilover kit. So I decided to just use stock torsion Bars for now. I had to crank them all the way down to get to about stock height.
The toe and camber were off big time so I used my tow truck and brought it down to a local tire shop (Ed's Tire Factory) and had them give it an alignment
The ride right now is soft and cornering is a trip. It leans really far and picks up the inside a lot but I never feel like its tipsy lol. I know with the coilover kit a lot of that will go away. I took it on a small dirt road run and the front seems to soak most of the bumps but now the rear needs to be done.
I am curious if there is any way to get just a little more preload from the stock torsion bars though. Does anyone have any ideas????
Old 06-08-2014, 01:55 PM
andersej's Avatar
Was able to torque down the Torsion bars almost all the way using a huge breaker bar. The ride height is much better and the suspension seems to have stiffened up some.
Old 06-08-2014, 02:03 PM
andersej's Avatar
Before and After pics...
Old 06-09-2014, 06:09 AM
d21cruisa's Avatar
Very nice, James! That Blazeland kit looks awesome!
Old 06-09-2014, 06:45 AM
  #25
chukarhunt's Avatar
Nice install! Makes me want a kit very badly! Looks like it will be a ton of fun.
Old 06-09-2014, 07:32 AM
  #26
andersej's Avatar
The only complaint I have so far is how bad it makes your rear suspension feel lol. Has anyone made the stock rear link a little taller and stronger using custom arms and such?
Old 06-09-2014, 05:33 PM
  #27
andersej's Avatar
Talked to Nate today from Blazeland to start some ideas for my rear suspension. I have to say that of all the places I've dealt with Nate is by far one of the best guys to do business with. He will take the time to help you figure out some of the questions for your setup. Big thanks again to Nate at Blazeland for your awesome product and advice.
Old 06-10-2014, 09:59 PM
  #28
andersej's Avatar
Installed 3 inch wheel spacers in the rear to match the front. Looks much better now.
Old 06-12-2014, 09:23 PM
  #29
BlazeN8's Avatar
James,
Great write up and pictures!
Be careful cranking the torsion bar to the max. If you go to far and gall up the threads it may be difficult and dangerous to to unload as the bolt will break and shoot through the floor pan. I recommend that when ever you adjust the torsion bars do it with the suspension at full droop and the weight unloaded. Use a floor jack on the center of the front cross member like you showed in one of your pictures.
A trick to get more pre-load to the torsion bar adjusting bolt is to add shims below the head of the adjusting bolt. Slugs or stack 1/2" washers. I had a batch of slugs cut with some laser cutting (3/8" plate) and made a shim stack 1-1/8" high. I was able to get a good bit more pre-load but the suspension was stiff and sagged fairly quickly. Adding more and more pre-load to a spring has a different effect than changing the spring rate.
Stock Torsion bars (22mm) just don't work with Long Arms, the leverage is just too much. Aftermarket T-Bars (24-26mm) will do the trick. I heard Kartek (google it) has Sway-A-Way T-bars in stock now after a long back order. But if your going Coil Over Conversion I guess that is a moot point. I'd love to sell you a shock hoop but an aftermarket sway bar is a big bang for your buck. Find some used ones, even better.
Oh by the way, I received your old LCA/UCA cores today. They were in good shape so I will be sending you the full deposit refund shortly. Oh yeah, the lower BJs were really pressed onto the LCAs, looks like you gave up trying to remove..... which is good, as some people force it and hammer the crud out of the drop and in doing so elongate the tapered hole, ruining the LCA in the process. Not a big deal for me to remove properly, I have the technology!
Not your actual cores, just a photo from my archive. Blazelander2013
Old 06-15-2014, 05:48 PM
  #30
andersej's Avatar
Originally Posted by BlazeN8
James,
I went to the dunes this weekend and the front handled SOOOOOO GOOOOOD I was flying across the dunes. I even jumped the damn thing 3-4 times without a problem. I am so impressed by your kit! I'll post some pics when I get them.
Just hold onto my deposit money because I am going to buy your coilover hoops here shortly
Old 06-15-2014, 05:49 PM
  #31
andersej's Avatar
Heres one
Old 06-15-2014, 06:21 PM
  #32
julsruls's Avatar
very sexy
Old 06-16-2014, 01:45 AM
  #33
andersej's Avatar
Old 06-16-2014, 01:53 AM
  #34
andersej's Avatar
The light setup worked sooooo well at the dunes.
Old 06-16-2014, 09:13 AM
  #35
Fryday's Avatar
What lights did you use and where did you get them? Looks good.
Old 06-16-2014, 09:28 AM
  #36
yota_terror's Avatar
I really like that Blazeland kit. Is it expensive?
Old 06-16-2014, 11:36 AM
  #37
pnwadv's Avatar
which bumper is that and also wondering about the LEDs attached to it. Looking really nice overall!!!
Old 06-16-2014, 06:36 PM
  #38
andersej's Avatar
http://under-glow.com/
For the rock lights.
and Ebay for the 24" lightbar.
Old 06-16-2014, 06:38 PM
  #39
andersej's Avatar
http://www.blazeland.us/
Its honestly not that bad. His prices are listed in the website
Old 06-16-2014, 06:40 PM
  #40
andersej's Avatar
I built the bumper myself. I got the lightbar off of Ebay for 89 bucks. It works really well just doesn't have huge distance out in the open. Thanks for the compliment!
Quick Reply: Andersej: 1993 2nd Gen 4runner
