94 SR5 Bear rig
Old 06-03-2012, 09:51 AM
Tony Gow's Avatar
94 SR5 Bear rig
Well I finally took the plunge and bought a yota .
Its a fairly stock looking truck with the 3.0 & a 5 spd
I know the gears have been swapped along with the rim and rubber
it started life with 225/70r15 & now wears 31/10.5 on 15x8 aluminum yota rim.
It turns 2500 to do 55 in fifth gear. If I have the math right it has 4.88 gears in the pigs
my goal is to have it be a rock solid little rig for the next several years so I am going to concentrate on getting the best mileage I can out of it and doing some body work . The motor is plenty strong was curious about other folks experience towing with similar rigs I would like to tow a small camper up to bear camp
Old 06-21-2012, 04:49 PM
Tony Gow's Avatar
after driving it a couple weeks and hitting some local trails it handles well good power posi in the axles definitely had the gears swapped. I am looking to change the exhaust ie actually having a muffler and get rid of the cat. I have to fix a starting issue and may have a bad O2 sensor pics will be soon
Old 06-21-2012, 05:06 PM
RMP8080's Avatar
picturesssssssssssssss
Old 07-06-2012, 04:39 AM
Tony Gow's Avatar
pic
Old 07-06-2012, 04:41 AM
Tony Gow's Avatar
so far its a tune up and a walker quiet flow cat back put on
Old 08-10-2012, 03:47 PM
Tony Gow's Avatar
average mileage is 20-21 time for shocks and brakes all the way around discovered it crawls really well up north chasing bears with the dogs
Old 08-10-2012, 06:17 PM
Rinker's Avatar
Sounds like a solid rig. What is your starting issue? I've noticed that mine doesn't start as easily when warm, so now I'm going to get a timing light on it. Just swapped out the distributor. Good luck with the 02 sensor and let us know if it helped out your situation. Happy trails to ya.
Old 08-10-2012, 08:49 PM
Tony Gow's Avatar
starting issue just went away didn't do anything but wires oil and air filter couldn't get the plugs out to change them
Old 01-10-2013, 10:59 AM
Tony Gow's Avatar
I have since added a Cobra chrome cb and 8 foot whip but I need a drivers side front spindle after loosing a outer bearing going 55 down the road anyone got one they can sell?
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
the1998sr5
15
07-14-2020 08:35 PM
82yodahickman
34
05-16-2017 01:00 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: 94 SR5 Bear rig
