1991 pickup 5.3 swap...they said it wouldn't fit
Old 04-04-2014, 10:43 PM
magpede's Avatar
oh well...at least it keeps you entertained..lol
I'm thinking having the exhaust dumped at the manifold is partly to blame as well as some distortion.
Old 04-04-2014, 10:51 PM
magpede's Avatar
My e-fan will indeed fit behind the radiator, corvette accessory drive is key as it sits the closest to the engine.
Old 04-04-2014, 11:04 PM
magpede's Avatar
The middle picture shows the difference between truck and corvette crank pulley offset. I decided to go with an underdrive pulley.
Old 04-12-2014, 06:44 PM
magpede's Avatar
Sorry for the lack of updates but I've been busy working on the truck. The dash is back in and I just ordered several more parts..just seems like everybody wants me to work on their stuff now. Everything seems to be working like I wanted...check engine light, clutch start cancel switch etc etc
Old 04-12-2014, 07:01 PM
  #25
JasonYota's Avatar
Subscribed. What transmission are you running?
Old 04-12-2014, 07:10 PM
  #26
magpede's Avatar
I'm running the r150 the truck came with...plan to have marlin do a HD rebuild on it later.
Old 04-12-2014, 07:14 PM
  #27
magpede's Avatar
Might not be able to tell it from the pic...but the trans is sitting back about 3.5 inches from the factory location.
Old 04-14-2014, 03:12 PM
  #28
LuczOr's Avatar
Nice! I just bought a 2002 Camaro z28 to steal the LS1 and put it in my '86 4runner. I have a bunch of questions I want to ask you!
Since the transmission is sitting back 3.5", are you going to have to do custom driveshafts?
Also, what motor mounts did you use? I was assuming that I would have to go custom, but if there is something out there that works, I would love to hear about it.
Also interested in what radiator you're using. I hoped I might fit the Camaro radiator in mine, but it's pretty wide. It's short enough that it can sit above the frame rails though.
Also interested in what headers you're running.
Let me know.
Old 04-14-2014, 03:23 PM
  #29
magpede's Avatar
Yes the rear driveshaft will need to be shortened. The front one is still connected but I question the amount of spline engagement so it will be lengthened. I'm using mounts from advance adapters for a 350 along with dirty dingo conversion slider mounts to make it fit a LS style engine. My radiator is from be cool for a 350 as well. I'm using manifolds on my truck...hooker lsx conversion manifolds...they fit the closest from what i could tell, their dimensions were very helpful.
Old 04-14-2014, 04:33 PM
  #30
kornhuskerwizard's Avatar
Interesting build!!
Old 04-20-2014, 04:20 PM
  #31
magpede's Avatar
Before anyone asks...I'm still running the factory fuel pump. I compared specs for the truck the engine came out of and the stock toyota pump and best I could tell it's sufficient.
Old 04-20-2014, 04:30 PM
  #32
magpede's Avatar
new parts
Size:  105.7 KBName:  IMG_20140416_124643_518.jpg
Old 04-20-2014, 04:33 PM
  #33
magpede's Avatar
Need to have a couple bends put into the lower pipe..no big deal.
Old 04-20-2014, 04:34 PM
  #34
magpede's Avatar
Oil pan part number
Old 04-20-2014, 08:01 PM
  #35
On the fuel pump...Im running a 4.3 cpi on my 87 truck and im stickin with the stock gm pump. Im curious to see how yours handles the stock toy pump. Lookin good the way.
Old 04-24-2014, 07:44 AM
  #36
Gizler00's Avatar
Man this is a cool build. I wold love to have the 5.3L under the hood of a Toyota. I love the 5.3L its a solid Engine!!
Old 04-30-2014, 10:41 AM
  #37
Jthod's Avatar
Love the build, I'm actually using the same engine in mine.
Can you see it fitting without the body lift? I'm doing a SAS at the same time, and using an F body oil pan, so my bottom end will be good. Most of what I've read has been transmission fitment, in using a 4L60, which I am.
What can you tell me about flashing the ECM to run as a standalone?
Old 05-01-2014, 07:58 AM
  #38
crum's Avatar
Just stumbled across your thread. I'm currently in the process of doing a LS1 swap into a 1991 v6 4runner. Just wondering if you would be able to post up a few photos of your sump and gearbox crossmember? I presume the C6 sump you use required no trimming and you haven't spaced the front diff down at all? I've currently got a GTO front sump on my doner engine which I'm debating whether to modify
Old 05-04-2014, 01:58 PM
  #39
mdb4879's Avatar
Lately I've been wanting to swap a 5.3 into my 86 2wd. Is a body lift necessary on a 2wd, or does not having to clear a front diff allow the motor to sit lower and provide necessary clearance? Or is trans clearance the only issue in my case? As much as I'd like a manual I'd probably go with a 4L60E, but I'm curious how a T56 or even some sort of a 5 speed would fit.
Old 05-04-2014, 02:01 PM
  #40
Discombobulated's Avatar
Ummmm, updates please
Quick Reply: 1991 pickup 5.3 swap...they said it wouldn't fit
