1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.
Old 12-17-2013, 04:31 PM
IIIIDamienIIII's Avatar
Angry 1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.
Alright everybody. I have just taken on something I am not 100% sure I am capable of doing. A little background: I just recently purchased a 1990 4Runner for $1000. It runs, just needs a little tlc. How could you pass that up!? So i jumped on it and started doing what needed to be done. First was the radiator, no problem. then the rear driveshaft, no problem. now i need to replace the head gasket and while doing so i am going to change everything else that i have access to while doing so.
In the picture i attached to this thread, is how far i have gotten. as of right now, i am stuck. i am not able to get the last bolt undone that holds the fan clutch in, but i soaked it with wd40 and tomorrow should be better. but the bottom belt that has the ac compressor (i think that is what it is called) will not loosen. I'm not sure what i am doing wrong.
and now that the timing belt is exposed, i have totally forgot what i should do. i don't want to mess my truck up, but i don't want to pay someone to do something that i can do.
so please, if anyone has any advice, please feel free to reply! anything helps!
Attached Thumbnails 1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.-img_0052.jpg
Old 12-17-2013, 04:39 PM
millball's Avatar
Follow the instructions in the factory service manual.
You can find several different links if you search.
Old 12-21-2013, 06:53 PM
4wdYotaBoy's Avatar
I'm 16 I just did timing belt water pump and the idler/ tentioner pulley last week just tak your cam shaft gears take the sheet metal cover off just keep pulling it till you get to the heads it a lot of crap there's so much in the way of the heads but it's really not bad
Old 12-21-2013, 06:56 PM
4wdYotaBoy's Avatar
Here is mine
Attached Thumbnails 1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.-image.jpg
voiddweller
19
05-02-2016 09:10 PM
crazypaint
06-23-2015 03:27 AM
Mutinebullfrog
06-18-2015 01:36 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.
