1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6
Old 04-13-2013, 11:25 AM
rykeebobee's Avatar
Arrow 1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6
Since I bought this truck just over a year ago I have replaced or added all of the following,
-Timing Belt, Tensioner and Idler.
-Water Pump and Thermostat
-Battery
-Air Horns
-Rear Main Seal
-Clutch
-Valve Cover Gaskets
-PCV Valve
-Radiator
-Mass Airflow Sensor
-Throttle Body
-Cold Air Intake
-Stereo w/preamp, 1000watt amp, and 2- 12" subs
-I replaced all of the lenses and bulbs on the front end
-I made a skid plate for the front out of stainless steel
-Converted a demilitarized pineapple grenade into my new shift knob
-Replaced the console
-Added a couple of fog lights
-New plugs and wires
-New water temp. sensor
I just made a new console for my truck, the old one was wore out. I made this out of solid walnut(No filler wood here).
I will add more pics as soon as I figure out how to get more than 3 on here.
I am considering topping this console with a coonskin from a coon I trapped this winter.
In a couple of weeks I will be replacing the front wheel bearings and cv shafts.
Old 04-13-2013, 11:32 AM
rykeebobee's Avatar
Pictures
More console pictures,
New and old side by side,
1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6-new-n-old-side-view.jpg 1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6-new-n-old-front-n-top.jpg
Base open setting on workbench,
Old 04-13-2013, 11:36 AM
rykeebobee's Avatar
More pics
This is before I stained the console,
These are after I stained the console,
1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6-rear-n-side-view.jpg 1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6-top-open.jpg
arlindsay1992
01-23-2024 01:34 PM
6th Gear
19
12-10-2019 07:31 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
bprice0077
06-25-2015 07:36 AM
Quick Reply: 1988 Toyota Pickup 4X4 SR5 XCab 3.0-V6
