Tony Battista's 1985 4Runner Build-Up Thread
Old 05-04-2009, 07:45 AM
Tony Battista's Avatar
Smile Tony Battista's 1985 4Runner Build-Up Thread
Here are some pics of what i have done so far and it has come a long way but i still have alot of work to do.
Replacing break pads, rebuilding calipers, regressing bearings and hub assembly
Cone washers are hard to get off!!!
Center Line Rims with 35x12.50 tires
Rotors
Newly rebuilt calipers
Hub parts
Right front strut
Repainted hub locks
Put a new stock carburetor on (needs adjustment)
Undercarriage before & after
After
SR5 Interior
Mossy Oak seat covers
Needs new B pillar covers
Back Seat Climate Control
Truck Bed
Roll Bar
Wiring for heavy bass system
Pioneer Stereo
I have the tools for the JOB!!!
Old 05-04-2009, 07:52 AM
yodercrawler55's Avatar
looks like a bunch of fun, when I get a little more money im gonna overhaul mine.
Old 05-07-2009, 11:08 PM
HiLuxer's Avatar
How big is your SL lift? Obviously you put 35's on. My ProComp is 4" and I'm planning on going 33's (295/75 16). Recently, I've found a deal on 35" Boggers and now am torn between the 2 tire sizes.
Old 05-08-2009, 03:20 AM
3 inch suspension lift in front and 3inch blocks in rear
Old 07-25-2009, 06:37 PM
Hayes's Avatar
how is the sound from those rear speakers? Does it sound good?
Old 08-05-2009, 09:14 AM
gary_the_4runner's Avatar
I need what you got
I want that altimeter on your dash!!!!
You know anywhere i can get one????
Im also looking for the turbo digital gauge cluster if you can help me with that.
Thanks
Old 08-05-2009, 09:30 AM
cblackard's Avatar
If you are referring to the cone washers that are in the hub assymbly that hold the locking hub tightly in place, they are not that difficult to remove.
Just loosen the nuts that hold the hub until they are just beyond the end of the studs, then tap them with a hammer and the cone washers will "pop" out of the taper for easy removal.
Old 08-05-2009, 06:38 PM
myyota's Avatar
3 inch A lift in front and 3inch blocks in rear
You would be better off with 3'' springs in the back instead of those 3'' blocks, 3'' blocks cause to much axle wrap.
Old 08-05-2009, 08:35 PM
olharleyman's Avatar
White lettering looks better on the inside black wall out imho.
Old 08-16-2009, 11:40 AM
TheBrownNote's Avatar
How did you go about cleaning up the undercarriage?
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jon.r
07-11-2015 03:34 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Tony Battista's 1985 4Runner Build-Up Thread
