Sam24th's 84 Darkside build
Old 10-11-2014, 11:48 AM
  #81
Googer's Avatar
Nice truck! I have an 84 I bought brand new, I noticed the truck bed on yours is different then mine?
Old 10-12-2014, 04:12 AM
  #82
tmarsh38's Avatar
Originally Posted by sam24th
Well a bit of an update. The yota has got some new permanent tires. Finally got some 32s for the yota. I also ordered a set of shackles for the front to level out the ride a bit.
Where did you get that bed rack?! I got to get me one of those!
Old 10-20-2014, 05:48 PM
  #83
yota81's Avatar
hows that rear bumper build coming?
Old 06-21-2015, 04:26 PM
  #84
sam24th's Avatar
Long time since Ive posted anything here. but I started on a rear bumper build for my pickup truck.
Also ended up building my buddy some sliders for his 4runner.
Old 07-06-2015, 06:12 AM
  #85
sam24th's Avatar
Finished the rear bumper for the pickup. I bought a winchplate for the front and will be building a new front bumper for it soon.
Old 07-07-2015, 12:54 PM
  #86
jerusry's Avatar
I like the simplicity of the rear bumper.very low key.I am hoping to build one like that for my 4runner
Old 07-19-2015, 07:59 AM
  #87
sam24th's Avatar
Just finished bending some more tubing and mocking up a front bumper. Still need to add a few more supports and finish weld it.
Old 02-01-2017, 06:10 PM
  #88
sam24th's Avatar
Been a really long time since I showed up around these parts. I decided to start building my pickup truck again. So I picked up a dual fuel kit for it recently. The kit is a got propane dual fuel kit. So I can run either gasoline or propane. I also have a painless dual battery system going int he pickup soon. Worked on the truck a bit tonight and ran into my first major snag. The intake seems to be sitting a tab bit too tall and the hood wont close. Im going to attempt to remove some of the ribbing in the hood since thats what its hitting on. If that doesnt work i may have to resort to cutting the hood or doing a 1inch bodylift.
Old 02-08-2017, 04:35 AM
  #89
sam24th's Avatar
Finally got the propane kit mounted in the truck. Mounted the vaporizer behind the drivers front headlight light with a bracket I made. I routed all the lines and test fired the engine on propane. Truck seems to runs great. Also ended up putting a hole in the hood and a small vent to clear the intake. Now I just need to finish wiring and mount the tank in the bed down.
Old 02-08-2017, 07:22 AM
  #90
TBJmedic's Avatar
What was the source for the over cab roof rack a few pages back??
Old 02-08-2017, 07:27 AM
  #91
sam24th's Avatar
It was home built. Ive since sold the rack. Im going to be making a different rack for the truck now.
Old 02-28-2017, 06:41 PM
  #92
sam24th's Avatar
Brown santa showed up at my house today. Got some goodies from trail gear for the pickup. Still waiting for some more parts. But I got a front top truss, shock hoops, and frame reinforcment plates. Also had a GM alternator bracket that ill be installing for dual batteries.
Old 03-26-2017, 04:16 PM
  #93
locke023's Avatar
Love the attention to detail, sweet truck
Old 04-15-2017, 08:26 PM
  #94
sam24th's Avatar
Some updates: Had a bit of frame rust on the passenger side. It was actually pretty bad, but I replated the whole passenger side and finished the Chevy 63 swap. Also got the truck pulled into the garage after the swap, and pulled the front axle for a rebuild and diff swap. Decided to pull the front locker and stick it in the rear. Then I pulled the ARB from the 4runner and am going to stick it in the front of the pickup.
Old 04-21-2017, 06:47 PM
  #95
sam24th's Avatar
Got the front axle housing apart and prepped it today. Cut the old Dogbone mount, stabilizer, and sway bar mounts off. Trussed the axle and gusseted it in a few areas. Got it painted and prepped to accept the ARB Air Locker.
Old 04-27-2017, 06:41 PM
  #96
Yota31's Avatar
Great looking truck! Love that color!
Old 06-01-2017, 07:44 AM
  #97
sam24th's Avatar
Then this happened the other day:
Old 06-19-2017, 05:36 AM
  #98
sam24th's Avatar
Brown santa delivered more goodies. I got my new 10k superwinch. I installed it on the winch plate and made a quick front bumper. Still need to add a hoop and braces. Also mounted my bilstein shocks.
Old 06-21-2017, 05:20 AM
  #99
sam24th's Avatar
Starting to get into more expedition type gear now. Mounted my aircompressor last night, ran all the wiring for the compressor and locker switch, and tested the solenoids. Still waiting for a couple fittings to finalize the compressor and tidy up the wiring. Probably going to make a new switch plate for the gauge and toggle that will go in the change holder (left open pocket in picture.) The tank itself is a 4gal tank which will be running at 150psi/110psi. Compressor auto kicks on at 110 and shuts off at 150.
Attachment 109345
Old 06-28-2017, 06:16 AM
  #100
sam24th's Avatar
Finished up a few more items and got a test run in with Carolina Trailblazers. I got part my sliders made and welded on the truck. Mounted my top light bar that I had for ages. Finished up the compressor and mounted my highlift in the bed. As far as the test run went, I found out I need a new front driveshaft lol. My driveshaft was too short and I lost 4wd on the first trail. So theres that.
Quick Reply: Sam24th's 84 Darkside build
