1984 4Runner asleep since 2006
We discussed the following items which I will order some of this week:
2nd gen V6 brake booster from Napa
96-98 FJ80 1" brake master from Napa
2nd gen rebuilt calipers for 4runner from Napa
Jeremy has a new set of rotors that we will use.
Custom order stainless brake lines.
Air pump is locked up so going to order another one from Napa.
Going to buy Spider Trax wheel spacers 1 1/2" to clear calipers with 2nd Gen SR5 wheels or FJ40 steel wheels with caps.
Tires will probably be BFG KO2 31x10.50x15
Also, are you considering the larger Tundra/FJ80 rear wheel cylinders? That is supposedly useful to maintain the original F/R braking balance after you upgrade the fronts.
Can't wait to see your parts come together!
Yes looks like I'm going with the later S13 caliper...Napa #ADC 1439XB rather than the S12 ADC 1169XA.
I don't like the wheel spacers either but Jeremy says that the Spider Trax wheel spacers are the best out there and the only one's to use, so we will see.
Maybe Wally will chime in, I will tag him.
I will ask about the Tundra/FJ80 rear wheel cylinders....thanks for that.
Mike
Mike
Mike
Mike
I ordered a 2nd Gen booster from a truck with supposedly 121K on it, we'll see what shape it's in when I receive it.
I think I have to use the spacers anyway because I may use the Gen2 SR5 wheels that are 15" with -8 offset.
Who did you order the Gin 2 booster from??? Used???
Mike
Mike
#25
The following users liked this post:
Saccyclone (11-06-2023)
#26
Don't use the Trail Gear knuckle rebuild kit. The bearings are the right ID/OD/thickness but the roller angler is wrong and the bearings are cheap quality. Buy anything with bearings from Marlin Crawler. The Marlin kits come with Koyo (OEM) bearings and are much better quality.
#28
Getting down to the wire on the truck and hope to have it on the street driving next week. Been a few months in total and lots of projects to complete.
The fuel tank was removed a few days ago and sent to the radiator shop to be boiled out, they said that the inside was a mess but no pin holes so thats a plus. Since they offered, decided it was a good idea to have the tank epoxy lined after it was cleaned out for added protection. Tank will be installed this weekend.
The problems continue however since the mechanic told me that the charcoal evap canister is clogged up and will not pass any air through it. I quick check online and I found that this is a common problem and even though I can find replacement canisters from Toyota on line, there are none available for purchase. Found an old thread on YotaTech of a guy who ended up taking his canister apart and cleaned the check valves and other parts to get his canister to perform........guess that's the direction I'm headed.
Ordered Hankook all terrain tires 31x10.5R15 that will arrive in a few days so that I can mount them next week on a set of 90 SR5 wheels that I bought. I already have the 1 1/2" spider Trax spacers for the brake clearance as i have the later S13 calipers so all should be well,.
A few pics of progress and hope to be driving it soon.
Mike
Mike
#29
Finally got my later model SR5 wheels mounted with new 31.10.5.15 tires.
Smog pump was seized up so I took it apart today, cleaned it up inside, lubed the bearings, put it back together and it spins freely again. Will install this week and see if it will keep spinning on a running engine.
SomedayJ (04-02-2024)
#30
Looks so much better with those SR5 rims. Good work so far.
The following 2 users liked this post by coryc85:
Saccyclone (04-01-2024),
#31
Looks great!
i need some of those.
Thankfully no smog pump, though.
#32
Finally, after owning this runner for a few years, it runs and drives, it smogged today, and I have it back home. It has been a long journey and thousands in parts and labor but it was worth it.
4Runner4Leon (04-03-2024)
#33
Congrats, that was a long road, I can't get over how much better it looks with those SR5 rims.
osv (04-05-2024),
Saccyclone (04-04-2024)
#34
that's great, mike. nice work. i bet that first real drive was a lot of fun.
sorry i couldn't help on the brakes. i'm running stock setups on both of mine, haven't investigated changing to the later v6 version. my brakes work really well as-is, even when i throw on the 33s.
Saccyclone (04-07-2024)
#35
This week I have been working on wire repair due to rodents, mostly in the engine compartment and the passenger side front fender well. Looks like I got repaired what I needed because I did a check of all the exterior lights and signals and was pleased everything works as it should. All electric windows go up and down and the heater blower works.
Today I removed the wiper cowl and did vacuum of that area and removal of leaves and walnut shells......I was really happy that there are no signs of rust and it just needs a good power wash left. I removed the front grill and broke some of the old grill clips which I ordered on Amazon. Replaced the front headlights so now both of those work, both high beam and low beam. After cleaning up the front radiator support and front grill I re-installed the grill and was really happy with the results.
Next few days I will re-install some wire looms and remove the radio power antenna so that I can get that repaired on the work bench. Clean up of the cowl area and re-install the cowl.
The following 2 users liked this post by Saccyclone:
4Runner4Leon (04-11-2024),
osv (04-11-2024)
#36
Done with the wire repairs and moved on to the engine bay cleaning which took some time but I am really happy with the way it turned out........
Wiper scuttle area
Engine bay.. little surface rust around the battery tray but it will clean up and I will treat it with some rust inhibitor.
probably bead blast the air cleaner and repaint...
Wiper scuttle area
#37
Wow! Looks great. Details matter!
Saccyclone (04-18-2024)
#39
Pulled out the blower box and AC box from under the dash and cleaned out the twigs, leaves, and walnuts from the blower box that would rattle around when the fan was turned on. All nice and quiet now and clean air comes out of the vents instead of a cloud of dust.
The following 3 users liked this post by Saccyclone:
#40
I’d like to sanitize mine, but don’t want to disconnect the a/c lines. Still running freon!
Saccyclone (04-25-2024)
