rustED's 83' yota build thread
Old 03-19-2014, 10:31 AM
  #81
rustED's Avatar
Originally Posted by kawazx636
If you are having trouble with burning through your welds on thinner metal you may want to try a thinner wire. If you don't weld thin metal enough to justify buying a spool of thinner wire then you can use a piece of copper or brass on the back side of the weld. A steel weld will not stick to copper or brass so an old trick is to hold copper behind the weld to support the puddle. The copper or brass will also help dissipate the heat away from the weld so you don't have to turn down the amperage as much and you can weld quicker. It also helps keep the back side of the weld flatter and reduce any dressing work you may have to do to achieve a flat surface over your weld.
Thanks for the welding tips, next time I'm at the scrap yard, I'll have to try to find a piece of bronze or copper to use for that. I usually use .035 flex core for thicker metal, but I had a left over spool of .030 flex core from my trailer project that I was using on the air breather, probably still too thick of wire. I was able to do a series of tack welds all away around, it felt pretty strong, I just used the black silicone to seal the seams, heres a couple pics of it finished. The pic on the right I had to pound the air breather cover out to allow more clearance for the carb, it looks pretty crappy, but at least I can run a filter until I have the funds to come up with a better alternative.
Size:  21.1 KB Name:  002_zps7531d5cf.jpg
Old 03-19-2014, 10:56 AM
  #82
Staff
kawazx636's Avatar
Yeah 0.030 is a little thick. 0.023 would probably be ideal for that thickness, but a series of tack welds is the alternative.
Old 03-19-2014, 12:39 PM
  #83
gillesdetrail's Avatar
I use 0.030 flux core wire to weld my 22gau rockers and floor, it works good you just can't have a continous weld, just a series of tacks. Hold the spool gun at a 45 degree angle to have less heat and hold it about 1.25'' from the metal, wait about half a second between tacks and weld on the side of the last tack where material is a bit thicker (if that makes sense). I am by no mean an expert but that's what I learned from youtube videos on body repairs lol!
Old 03-20-2014, 10:45 AM
  #84
rustED's Avatar
Thanks again guys for the tips, I don't have that much experience welding thin material, I prefer the thicker stuff, lol. Hopeful I won't have to weld that thin of material again for a while, but if I do I'll have some good info to refer back to.
Old 04-11-2014, 10:34 AM
  #85
Ceveland's Avatar
Ed,
The trucks looking pretty sweet! I want an older pickup like that so bad. Keep up the hard work.
-Tim
Old 04-13-2014, 12:16 PM
  #86
rustED's Avatar
Red face
Originally Posted by Ceveland
Ed,
-Tim
Thanks Tim, unfortunately I'll probably be selling the 83'. I originally bought it to use as a daily driver so i wouldnt have to drive my 4 runner so much, but its turning into more of a project than a dd. The motor is getting tired and will need a rebuilt soon, front axel needs gone through, and a bunch of other little stuff. My uncle is interested in buying it, so I'll probably sell it and put the money towards fixing up my 4 runner more (6" AllPro rear suspension, new aluminum radiator and 16" fan, and hopefully finish up my offroad trailer build. I hate to sell it, but I have too many projects, and not enough $$$!
****************************************EDIT 05/06/2014********************************************** *********************
I HATE TO SEE HER GO, BUT I SOLD MY 83' BACK TO MY UNCLE. SHE HAD LOTS OF POTENTIAL, AND WILL BE MISSED!!!
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
young buck
18
08-27-2018 02:40 PM
thefishguy77
07-30-2015 10:59 AM
Quick Reply: rustED's 83' yota build thread
