Look what I found! 1981 Trekker!
Old 01-14-2013, 11:46 AM
HighLux's Avatar
Ran out and grabbed a new battery and some starting fluid.
She will fire with starting fluid and run for a sec...
Put a couple gallons gas in to no avail.
Obviously not getting fuel.
Whats my next step?
Old 01-14-2013, 12:03 PM
Logan81Pickup's Avatar
Clean them jets out.
Edit: Actually first take the fuel line off the carb and see if your getting fuel there first. If not, then you'll have to check the pump and then tank.
Old 01-14-2013, 12:19 PM
HighLux's Avatar
Checking that right now bossman!!
Old 01-14-2013, 12:25 PM
HighLux's Avatar
no fuel getting to pump.
Old 01-14-2013, 12:32 PM
  #25
Is the pump working? If there is rust in the tank the pickup could also be clogged.
I'm not going to suggest sucking on the fuel line, but it's a possibility.
Old 01-14-2013, 01:10 PM
  #26
HighLux's Avatar
Ok a little closer. I slapped a new fuel filter and pump on it...now its getting fuel to carb.
Still not firing on its own. Takes a squirt of starter fluid...then it fires for a sec...then dies.
I assume I need to get into the carb now?
Old 01-14-2013, 01:19 PM
  #27
Fossilized
Staff
dropzone's Avatar
$3-5 for a fuel filter...look for it on p/s wheel well
Edit--whoops didn't see page two.
Check plugs/wires and dist. Timing..
Old 01-14-2013, 01:34 PM
  #28
HighLux's Avatar
Its getting fire. Its down to the carb at this point.
Gummed up Im sure.
Gonna go try something..
Old 01-14-2013, 02:29 PM
  #29
HighLux's Avatar
Oh boy I got a project on my hands..lol.
Ever see one of these?
Original Winnebago warranty card. Like a credit card.
Tucked away safe and sound.
Old 01-14-2013, 02:30 PM
  #30
HighLux's Avatar
Old 01-14-2013, 03:45 PM
  #31
Gummed up Im sure.
Take the carb apart, soak the jets in carb cleaner, blow them out with air. Also clean any gunk out of the float bowl. If it still doesn't fire it's probably ignition timing.
Old 01-14-2013, 03:54 PM
  #32
HighLux's Avatar
Logan...it fires up and runs for a few seconds with starter fluid.
Im looking at carb kits now...and just happen to have a gallon
of chemdip from rebuilding my 1973 rd350 carbs over the summer.
So looks like Im rebuilding the carb.
Also...this truck was meticulously maintained until 1992.
I got records for every oil change...filters. This guy followed the Book on maintaining it. Changed diff and trans fluids on schedule. God I wish I was so anal...lol.
Original owner is going to send me a couple pics of when it was new.
The floor pans have me worried sick.
Anyone make patch pans?
Old 01-14-2013, 04:03 PM
  #33
Cut out the rusted metal and replace it with non-rusted metal? For the fiberglass part you'll need to learn to do fiberglass.
Old 01-14-2013, 04:16 PM
  #34
Fossilized
Staff
dropzone's Avatar
Find a donor floor pan.
Post some pics of the floor..
Sucks the meticulous maintenance ended 20 years ago. what's is the story behind the truck's decline into the abyss?
Do you have the Winnebago build date sticker on the lower left side of the dash?
Old 01-14-2013, 04:36 PM
  #35
HighLux's Avatar
Yes the sticker is there...looks new..lol.
Ill go get a pic.
BRB
Old 01-14-2013, 04:37 PM
  #36
slacker's Avatar
ohh , yeah sorry to hear about the floor rust . it is pretty common on this Gen
though .. dont know if this will help .. but have a peek anyway https://www.yotatech.com/forums/f209...r-rust-262324/
on the Trekker board , there are some pics of removing the rear back 1/2 , it might help as well .
Old 01-14-2013, 04:47 PM
  #37
HighLux's Avatar
Here is the winnebago sticker.
Look at all this attention Im getting!! I feel like a hot slut now!
Old 01-15-2013, 05:02 PM
  #38
HighLux's Avatar
Well. Day 2.
Been getting some offers on the trekker. I am more than likely let her go. She's a little more than I care to start with. I really wanted a pickup. And I honestly really dont feel like doing the floor pans. At one potential purchasers request Im not doing anything else to it. They want the barn find feel to it when it
arrrives.
Im really not looking to make a profit or anything but I intend on recouping my expendetures and maybe a lil treat for me.
I feel like Im changing my mind every tens minutes on this...
So if you know anyone who may want this thing..lemme know.
Otherwise Im feeling pretty sure this guys gonna buy it.
Old 01-15-2013, 05:15 PM
  #39
duckmaster88's Avatar
she looks really good a lot of work ahead but thats what makes it special!
Old 01-16-2013, 03:05 AM
  #40
bigt's Avatar
really cool truck man... but it looks to be a VERY INVOLVED and expensive rebuild...
would def be worth it when complete but unless you can do all the work yourself its gonna cost a small fortune...
I would almost let her go and look for a early pickup with a nice body and frame... I personally dont mind fixing mechanical issue but body work is a bit of a drag..
i appreciate the pics as i have always wanted a trekker or trail blazer
Quick Reply: Look what I found! 1981 Trekker!
