ditchdrift's Freebie 1983 Build Up
Old 01-30-2011, 01:59 PM
  #61
ditchdrift's Avatar
It actually increases the static compression ratio by quite alot, not decrease. I had the pistons fly cut about .3mm's so the compression should be in the 10.5:1 range. I used this calculator to figure it out.
http://www.csgnetwork.com/compcalc.html
Old 03-06-2011, 10:33 PM
  #62
JBurt's Avatar
Any updates?
Old 03-08-2011, 06:41 AM
  #63
truckman1966's Avatar
thank you ditch. i was shaking my head as i was reading that....
Old 04-13-2011, 07:03 PM
  #64
ditchdrift's Avatar
Well, i'm real busy at work so its hard to find time to work on my junk. But i got the pistons and rods installed. Next i have to prep a cylinder head.
Old 04-13-2011, 08:18 PM
  #65
SC81YOTA's Avatar
Originally Posted by xxxtreme22r
you can always tack it in place with superglue or jb weld. Then weld it.
Lucky for you it's not a pressure bearing part, but there is no way I see this happening on a DD. I have seen it happen to a drag car or two though. One the block the other the trans housing.
This is one reason of the many reasons to run a scatter shield. But not necc on a DD or a wheeler. I don't even think they even make one for any 22r transmissions.
Only thing I can think of is someone either had the motor or trans out at one point and did not have it fully lined up when torquing down the trans housing bolts.
P.S. Was the support brackets on the bottom of that block on both sides?
Ive seen this before. No factory support brackets to the transmission or they ran broken motor mounts for to long. Either way I bet they drove it home!!
Old 04-23-2011, 08:09 PM
  #66
ditchdrift's Avatar
Making more progress, i pieced together a timing chain kit with HD guides.
I cleaned up the head and did a damn good lap job on the valves, i have perfect sealing using a vaccum tester on the combustion chamber. Also smoothed out the runners and gasket matched intake and exhaust.
Old 05-31-2011, 05:20 AM
  #67
over a month since engine rebuild pics??? what happened?
Old 06-24-2011, 02:44 PM
  #68
1986yota4x4's Avatar
updates? i would love to find a 1st gen yota, definetally a score for free!
Old 01-26-2014, 02:41 PM
  #69
ditchdrift's Avatar
well, after an almost 3 year hiatus, im starting to work on this project again. I'll try to get some pics of the progress.
Old 01-27-2014, 09:19 PM
  #70
ditchdrift's Avatar
OK, well the motor is in and the EFI is all wired in, i just have to clean the wiring up a bit and make it look factory. All i really need to do to get the motor running is find an EFI gas tank and get a efi throttle cable. The ECU is located above the glove box and is tucked away real nice.
Old 01-27-2014, 09:21 PM
  #71
JBurt's Avatar
Looking great. Glad to see you're back.
Old 01-27-2014, 09:24 PM
  #72
ditchdrift's Avatar
Thanks, its really not going to look that great. its mostly a budget build to be fun. Its going to get doublers, w56, 5.29's, locker, hi steer with hydro assist, 36" tsl's, rears up fronts, and 51" springs in the rear. Its actually just going to be a fun bomb around rig.
Old 01-27-2014, 09:52 PM
  #73
JBurt's Avatar
That would look pretty great to me. Any plans on bobbing the bed?
Old 01-27-2014, 10:29 PM
  #74
ditchdrift's Avatar
most likely will bob the rear, i might also section out a part of the front and shorten the frame. but thats later in the project. currently, all it is is a rusty body, 2 diffs, and a motor.
Old 01-28-2014, 05:47 PM
  #75
ditchdrift's Avatar
Got a throttle cable installed, finished up the wiring, and finished the air intake setup. Now i have to see if i can get a efi tank out of an 86 truck to work.
Old 01-31-2014, 07:14 PM
  #76
ditchdrift's Avatar
Got the transmission and crawl box in. Cut a hole in the floor for the crawl box shifter. Making some progress.
Old 02-03-2014, 04:11 PM
  #77
ditchdrift's Avatar
Here's the shifter arrangement with the 2 cases. i might hack up the floor more to see how high i can get the driveline.
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
kawazx636
09-29-2015 08:22 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: ditchdrift's Freebie 1983 Build Up
