'78 Chinook Newport Project
Old 03-11-2013, 07:05 AM
83
83's Avatar
Did a little more work. Got the inverter wired for 120V (haven't started 12v yet), new furnace is in (just not mounted or connected yet), and I got the foil insulation in everywhere except the cab over. I'm still gutting that part a little, and it's giving me issues...
Cab over. The window frames hold in the pleather material and insulation. They're held in by screws. All the screws are really corroded. I can't get most of them out, so I can't ge the window frames out...hard to get stuck, corroded screws out with a screwdriver. Bolts would be different. Not sure what to do here.
This thing makes a lot of noise going down the road. A lot of it will be taken care of with what I've already done, but I'm trying to find anything else that might rattle. The padding for the bed in the cab over is foam glued onto plywood, with pleather stretched over it. And it just sits on blocks on the fiberglass. Definitely catching air and slamming back down when I hit good bumps. I'm not going to try to anchor it, really, but I'm gluing some foam to the bottoms of the blocks, to quiet it down a bit.
Old 03-18-2013, 06:49 AM
83
83's Avatar
Did a little work over the weekend. Taped the seams of the foil insulation, and got new seats in! Gigantic improvement over stock, and no modifications to my cab, no welding, no rigging up brackets.
Since I don't weld, didn't want to pay money, and didn't want to do a hack job of it (like I kind of did with my 83...seats are a little unstable and don't slide well in the tracks), I thought for a while about how to get these in.
My idea ended up working. Take the tracks off the old seats and put them on the new seats. As long as the new seats aren't any wider, there then shouldn't be any reason they wouldn't just bolt right into the existing holes in the cab.
The only thing I had to do was drill one new hole in the old tracks, one for each of the four tracks. The threaded holes on the new seats were just a little shorter-spaced than the old ones.
No welding! No fabricated brackets! Holes line up perfectly, seats feel solid, and slide back & forth smoothly.
Front holes
Back holes
And the result. This is the best thing that's happened since I started putting things back together. The original seat was uncomfortable. Not uncomfortable after a long trip, or an hour, or even a half hour. Just immediately uncomfortable when I sat down. Things poking me in the lower back, etc.
One of the next steps:
Old 03-18-2013, 09:41 AM
aviator's Avatar
Stylin' seats bro... if you go to a car interior place they can hook you up with some similar fabric and you can do the door panels to match.
Old 03-18-2013, 09:45 AM
Pastor Bug's Avatar
Love the forward progress... Got to love it when things actually turn out right without a huge struggle.
Old 03-18-2013, 09:47 AM
  #25
83
83's Avatar
Thanks guys!
It would be nice to get some matching fabric...
Old 03-18-2013, 09:53 AM
  #26
Black_1985_SR5's Avatar
Subscribed good work keep it up
Old 05-06-2013, 01:37 PM
  #27
Rusker's Avatar
Subscribed!
I was about to start a thread about my own Chinook build since I've starting working on it this weekend. Your thread is the motivation I need to finish mine as well. Haha
Any updates?
Old 05-06-2013, 01:40 PM
  #28
83
83's Avatar
Soon. I've been doing a lot...but a lot of it is invisible, and prep work. Once things really start going back together I'll have a few posts with lots of progress. It's going to be functional for camping by mid-June, so there will be a lot of progress to report on soon.
Old 05-06-2013, 04:17 PM
  #29
Rusker's Avatar
I'm also hoping to use it towards the end of summer.
What vehicle are the new seats from? They look so much more comfortable than the stock ones.
Are you still running with the stock carb.?
Old 05-06-2013, 07:00 PM
  #30
83
83's Avatar
Mine should have been in use by now...but I always forget how much longer things take than I plan.
Either a Honda or Acura. Same thing, basically. Early 90's model. They fit really nice, and are very comfy on their own, but compared to the stock seats...WOW.
Yes, on the stock carb, but we'll see for how long. It does need some work, and I've been curious about Webers for a long time...so this may be the vehicle I try one out on.
Old 05-07-2013, 07:11 AM
  #31
Rusker's Avatar
I'll keep an eye out for similar seats. My stock ones are in good condition, but I can't imagine how'd I'd felt after being on the road for a few hours.
I'm also looking into the weber. I've read a lot of good things, but my stock carb is working at the moment.
Old 05-07-2013, 09:12 AM
  #32
86bedlesstoy's Avatar
Sweet ride. Good luck with the build!
Old 05-07-2013, 09:19 AM
  #33
phildelfino's Avatar
subscribed. good luck with the rebuild.
the modern touches will be more energy efficient, also.
seats look good and comfy.
i'm guessing the 5 speed just bolted right up.
no experience with the older 4 cylinders.
have you thought of installing a solar panel?
Old 05-07-2013, 11:50 AM
  #34
83
83's Avatar
I'll get solar eventually. If I plan on staying out places for more than a weekend, without having to run the engine, I'll need it. But for this summer, I'll just see how it does for 1 & 2 night trips. No microwave, tv, ac, or any of that, so it won't draw much power.
Old 05-07-2013, 12:13 PM
  #35
83
83's Avatar
Working on the new walls. Cutting, sealing, putting frames on.
Insulating the walls. Putting upholstery foam on the back wall panel and ceiling, along with insulation.
Vinyl stretched over the ceiling and back panel.
So the ceiling and back panel are insulated, padded, and covered with vinyl. That's how it was when I bought it and I didn't see any reason not to do it that way again, with all new materials.
Walls up.
LED bulbs in old light fixtures. Some I soldered directly in, others I just bought bulbs that connected into the old incandescent bulb location.
Other things...I've rewired everything (just haven't put the fixtures in), been spraying PB Blaster on the leaf springs getting ready for the add-a-leaf and new shocks, painted the mirror mounts and am getting the new mirrors mounted on them, and I've started framing in the cabinet that the stove, furnace and fridge sit in.
Ceiling is almost ready to go up. It came down in 3 peices, I only have one peice ready so far and they all need to go up at the same time.
Old 05-07-2013, 01:55 PM
  #36
83pingpong's Avatar
I missed the point where you managed to pull the window frame screws (ground off the heads, then twisted the stalks after removed frame?). Obviously, you found a way to deal with them...
The new walls look excellent (and insulated-YES). Where is the noise coming from when you mentioned when you drive down the road? I had loose front bumper and still have at least one heat shield to find and pin down, and something in the right door. On the Chinook, it could be inside a cabinet, or wall!
Great idea on the lights. Where do you come up with the time!?
Old 05-07-2013, 04:43 PM
  #37
83
83's Avatar
Yeah, I bought a impact screwdriver, and it got the last screws out no problem. Except the ones in the cab-over...I think I'll need to drill those out. The angle is no good for the screwdriver.
Thanks! The noises were partially from unsecured pieces of wood slamming when I went over bumps, like the padded "bed" area in the cab-over, and other parts of benches and cabinets that just kind of sat on the floor, but weren't attached. Other noises were from cabinets that loosed up or pulled screws out, and were moving around. Driving around on roads is hard on wood construction!
I get single-minded about things...which is why it's rare that I start projects. I like free time. But once I got going, I had to finish it. Now it's summer and I'm hating that camping weekends are going by, and I'm still sleeping in the back of my truck!
So, an hour or two or three after work, a half day or two on the weekends...I've just been doing stuff little by little over the last 4 months. It adds up, but not fast enough...
Old 05-07-2013, 04:56 PM
  #38
babyfood1217's Avatar
what a great project! Super excited to follow this!
Old 05-07-2013, 07:19 PM
  #39
JBurt's Avatar
Great progress. Where did you find the led's that plug into the incandescent fixtures? Those look awesome.
Old 05-07-2013, 08:01 PM
  #40
ThatGuy1295's Avatar
This is just ridiculously cool. Makes me want to drive to montana and help.
Quick Reply: '78 Chinook Newport Project
