1980 Toyota Crawler Build/Rescue
Old 04-03-2018, 12:21 PM
willdrach's Avatar
Hi Yotatech!
This is the build on my 1980 Toyota pickup. I just went ahead and copied everything from my original post on IH8Mud. Figured I'd come here too since I've learned tons from lurking and decided to join!
1980 Toyota Pickup 4x4
20R 4cyl - Unknown mileage, truck has 226k
5 speed out of a 1984 Toyota Pickup
Front axle out of a 1984 Toyota Pickup
1996 IFS Rear axle
5.29 gears F&R
Lockrite locker in front, Yukon in back
SOA Lift
33x12.50R15 Cooper Discoverer STT Pros
I bought this truck off of the previous owner in December. I wasn't really looking for a truck but saw it on craigslist and I just had to have it. He was only asking $1500 but I knew it was going to be a project so I went and checked it out, thought about it and bought it! He told me that everyone who messaged him just wanted to part it out, which really bugged me so I promised him that I would get it back on the trails. Steve had owned the truck for 22 years and built it himself. He was ecstatic to hear that I was going to get it back up and going and wasn't going to part it out.
The truck is definitely rough and he told me it hadn't been driving and was sitting for a couple years. Recently he had pulled the gas tank and boiled it since ˟˟˟˟ was getting sucked up and going into the carb. When I bought it it didn't run very well and had a pretty bad misfire. It would die once it was warmed up and the choke was off, so he actually towed it back to my house for me.
Here are some pics from the original craigslist ad:
Here she is the first night in my garage:
I knew when I bought it that it had some pretty immediate needs.
First things first, I wanted to see if I could get it to run better. It would start beautifully cold and once the choke died it wouldn't hold an idle. No matter what I did with the idle screw it didn't change. After further inspection, I noticed the plate that the idle screw pushes up against was bent backwards so it wasn't doing anything. I decided to put off bending it back until I rebuilt the carb.
Next were tires, oil change, tune up and replace the wing window.
Old 04-03-2018, 12:22 PM
willdrach's Avatar
A couple weeks went by and I was pretty busy so it just sat in the garage. I bought the carb rebuild kit and had everything I thought I needed to rebuild the carb. Being a young kid born in 1995, I will say that carburetors are not my strong suit at all. I'd had experience toying around with the ones on dirt bikes but I'd never rebuilt one off of a car so I needed some help and figured who better than the guy who sold me the truck!
Steve came over and we went ahead and started rebuilding the carb. Everything went really well, and we chatted and I had a great time. He told me some great stories about good times he had in the truck.
Of course, things were going too well and something was bound to go wrong. The rebuild kit I had bought on eBay did not have a dust shield for the accelerator pump. So after some calling around, I was able to find that the AutoZone not too far away had a rebuild kit with that dust shield. Went down and bought it, put it back together, bent the tab for the idle screw and threw it back on.
She fired right up and ran great! Messed with the tuning a little bit and she held an idle and purred like a kitten. Was super stoked and drove it around the neighborhood and it was running great.
willdrach's Avatar
After I rebuild the carb I started focusing on the other things the truck needed. One of the biggest was tires, and I was able to score 5 33x12.50 15 Cooper Discoverer's for $275 off of a guy locally. Threw them on the truck and god did it improve the driveability. With the old tires it would wander all over the road.
I also went ahead and replaced that wing window, and for my own curiosity I washed the truck to see if the original paint would shine up a little bit - and it did!
I fixed a couple more small things that it needed. Jerry rigged the hood latch so that it would work, put a new switch in for the headlights (used to have to jump the wires) and cleaned out the inside.
I even decided to enter it into the car show at the 2018 Roadkill ZipTie Drags. Drove it all the way out to the dragway (which was like ~50 miles roundtrip) and took my girlfriend out wheeling for the first time in it. The thing is a beast!!
Overall I was blown away by how reliable the truck was and even more blown away when I took it offroad the first time! This truck was slowly earning a place into my heart.
Old 04-03-2018, 12:23 PM
willdrach's Avatar
The truck sat for a little bit after the ZipTie drags since it wasn't registered and my temporary tag expired. Here in Tucson we have to undergo emissions testing and I knew there was no way that it was going to pass. As I tried to find a way to get it to pass emissions I did drive the truck around the neighborhood and started it up every now and again just to keep it going.
It was still misfiring a little bit and after further inspection I could hear the chain hitting the timing cover. Steve had told me about this when I bought the truck and I had intended on doing it, but since it was sitting and not even able to be driven I figured it was as good a time as any to go ahead and rip into the timing chain.
I took my time, went slow and made sure everything was done right. Couldn't even begin to tell you how bad the old chain was. There were 4 or 5 links sitting in the bottom of the timing chain cover. Spent most of my time just cleaning everything. The timing cover was covered in so much gunk it took me 3 hours and a lot of purple cleaner to get it somewhat back to where it was.
Also replaced the oil pump and water pump while I was in there. The stupid aftermarket pump had an extra hole in it for no reason, so I tapped it and put a plug in it (also covered it in RTV to make sure it didn't leak). Looks tacky, but it hasn't leaked at all!
Dropped the pan and was surprised to see no metal shavings!! Took a wire wheel to it and painted it up all nice. Tried to get the dent out but wasn't able to.
After I put it back together it ran great! The timing was perfect and I also put on new plugs, wires, distributor cap, rotor and a new coil.
Here she was the first day out of the garage:
willdrach's Avatar
In the weeks after the timing chain was replaced I drove the truck more and more. Still in the neighborhood but was driving it every day.
I bought some used off-road lights for the truck and threw them on. Steve used to have lights on there and his wiring harness was still there, so I just tapped into it and wired them all up.
Finally I was able to get it registered and then I started driving it around town. All was going well with the truck. It ran beautifully, was starting up nicely and just overall was really reliable. And then one day it all went.
I drove the truck about a mile down the road from my house to run an errand. On the way back all of a sudden I noticed a huge loss in power. It wouldn't get past 35 mph in 3rd gear. I was able to limp it home and once I did I looked the motor over and found a significant amount of coolant in the oil. The head gasket had blown.
I posted another thread on here discussing what my options were and what I was thinking about doing. I was debating whether I should think of this as an oppurtunity to redo the motor or to build a 20/22R hybrid. I wasn't sure if there was any collateral damage done to the motor since it had overheated. After much thought I decided to go ahead and just replace the head gasket and see what happens. I figured an $11 part and a couple hours working on the truck was worth it to see if I could get it to run again, so I found myself tearing the top of the motor off...again.
Sure enough there was coolant sitting on top of the piston in the cylinder.
Got the motor put back together, changed the oil and filter, replaced the temperature sending unit and it started right up! Took it on a test drive and it did great. Didn't overheat and when I got home I checked the oil and it was all good.
Here's how she's sitting today:
That's pretty much everything I've done to the truck thus far. I have many more plans for it and will definitely be keeping all of you posted on it!
Old 04-03-2018, 05:11 PM
Fossilized
Staff
dropzone's Avatar
Dunno if you posts on Mud had your pics as attachments but not of them transferred over.
Old 04-03-2018, 05:27 PM
old87yota's Avatar
Hummm....
The pictures show up for me.
Old 04-03-2018, 10:54 PM
det107's Avatar
X2....Good job on the resurrection-
Old 04-04-2018, 01:39 AM
JohnnyCanuck's Avatar
Looks great!
Old 04-04-2018, 08:09 AM
YOUNGIAM's Avatar
Looks great, love those old Toyota's.
Old 04-05-2018, 07:41 AM
willdrach's Avatar
Thanks everybody for your feedback! Much appreciated!
Here's a little treat for everybody. Steve sent me a picture of the truck from way back when. As he said, this is the truck "before all the carnage happened". Taken back in Sedona in 1997.
Also took the Ol' Gal to the guys down at Alignment, Brake & Suspension here in Tucson. They've done some work for me in the past and do a great job aligning lifted off-road rigs.
Of course they found a couple issues in the front end, some of which I didn't know about it. So it looks like I got a couple little projects ahead of me...
Here's the tech's notes on the front end. I told them to "set the toe and let it go"
I think the next thing I'm going to do is check the wheel bearings in the front. That's kind of a big deal!
Anybody have some good shocks they would recommend? Not sure what shocks are on it now but I'd like to keep it the same height if possible.
Old 04-05-2018, 08:13 AM
Punjab's Avatar
Excellent work! Keep it coming.
Old 04-06-2018, 06:41 AM
95yoda's Avatar
Nice work. Glad more build threads are coming up for our first gens.
cregs1119
19
08-22-2013 01:42 PM
benwilliams1226
05-14-2013 05:25 AM
benwilliams1226
10-18-2012 10:53 AM
CDUFF7
Vendor Advertising
06-21-2011 07:06 AM
Quick Reply: 1980 Toyota Crawler Build/Rescue
