FS: 22RE Turbo Manifolds
Old 03-22-2006, 04:13 PM
Full Boogie's Avatar
OK, one manifold left, uncoated, pics up in the first post, $150 Shipped anywhere in the lower 48.
Thanks,
Full Boogie
Full Boogie is offline
Old 04-05-2006, 12:20 PM
ToyotaGuru's Avatar
Still Got It?
ToyotaGuru is offline
Old 04-17-2006, 05:34 PM
yes
Later
Old 04-18-2006, 12:22 AM
robrub00's Avatar
I am working on my 22rte project for a while and I was going to throw on a ct26 cuz Funds are low right now, Could a adapter plate be made to fit the ct26 off a supra, My ct20 I just dont trust to throw back on after the rebuild, What Turbo were you selling locally with this set up or what could you recomend if I wanted to go with something else? or could you rebuild by ct26 if so how much, My engine IS being bored, honed, new cam , blah blah ,blah and New 22rte pistons put it, It was a stock 22rte out of an 86 turbo truck, I was just going to enlarge the holes on the ct26 and clock it etc, Also I was wondering what size exhaust outlets you used on the flange for the manifold, I know lc engineering has 2 sizes One stock and one slightly bigger, Is that better for a turbo application in your opinion, sorry for all the questions your manifold seems like a good deal I just need to figure stuff out first, also How much to coat it?
robrub00 is offline
Old 04-19-2006, 08:09 PM
  #25
robrub00,
An adapter would have to be made to bolt the CT26 to this manifold, with the stuff being done to your motor I think you would benefit alot from a Garrett T3/T4 turbo, I run a SC50R on my '94 4x4 truck, that turbo is a ball bearing that is the smallest of the "SC" series and is an excellent performer on my stock engine, even if you went with a SC50 (non-ball bearing) you would be able to produce close to 400 wheel horsepower as long as your engine/fuel system are up to the task. I currently have a GT28 actuator running a internal gate set-up that makes in total 8 PSI, and I have 8 PSI right at 2700~2800 RPM, even with running low boost like that you would have a more efficient (cooler charge temps) set-up running a SC50 versus your CT26. About LC flanges, yes the ones I get from them are the larger ones 1 5/8", the smaller one is 1 1/2" and is all cut out for the emissions crap, we also had the flange copied and have stainless steel flanges being cut as we speak because we have a header we want in full production and it doesn't make much sense like with LC's "stainless" header using a mild steel head flange.
Lastly, as far as coating it for you, to be safe I would say around 75~100 bucks. I can't really give you good quote on that because 95% of the stuff we do is all stainless or stainless and aluminum, so we don't get anything coated that often.
Thanks,
Rick
Old 05-03-2006, 07:02 AM
  #26
straightaxle85's Avatar
what comes with the kit u mentioned above?
straightaxle85 is offline
Old 02-26-2007, 10:28 AM
  #27
xmig21's Avatar
any manifold still avalibale?
xmig21 is offline
God's Bounty Hunter
10-23-2015 09:44 AM
RatOmeter
10-22-2015 03:17 PM
toofly1999
07-25-2015 07:09 PM
karbin
07-05-2015 11:37 PM
Quick Reply: FS: 22RE Turbo Manifolds
