'98 4Runner Limited - Parting Out - Oklahoma
I don't need the whole shifter, just the bezel that goes around the shifter that has the gear indicator on it. My gear indicator is cracked and broken and the ones I found in the junkyard were cracked. Any cracks on the part that indicates the gear?
#25
The shift lock is a little pin thing you can pull out, it is in the top right hand corner of the bezel to the right of the shifter. If you don't see a hole there then it is still there. mine has a hole. The $25 is that for just the bezel or the whole shifter?
#26
No, I was pricing the whole shifter at 50. I need to check out what I have and if the bezel is part of the shift window. My truck is not at my house. I will check it out tomorrow and get back with you. I hope to get a pic for you. Let me know your email addy and I will send the pic. My email addy is tengaokie@aol.com
Thanks
Chris
Thanks
Chris
#30
does it have the twist heater control or the slide heater control? if it is the 2 knob twist, how much? also need a skid plae and there is a little tab that goes on the window trim on the back door. thanks
