'88 4runner part out (rolled) Santa Rosa, CA
Old 03-09-2012, 06:30 AM
Harry Comes's Avatar
How's the "L" trim around the rear sliding windows? How much shipped to 12053?
Harry Comes is offline
Old 03-11-2012, 01:59 PM
gottadog's Avatar
Also interested in the cluster. I'm in the east bay if you ever come out this way. PM me if you still have it for sale with a price.
gottadog is offline
Old 03-12-2012, 07:26 AM
Hothondaguy's Avatar
PM and Email sent!!
Hothondaguy is offline
Old 03-13-2012, 08:05 AM
any word on the Hubs yet? Paypal has been sent.
Old 03-13-2012, 05:44 PM
  #25
fullwidthyotaon40s's Avatar
Hondaguy, hubs shipped today priority. Not 100% sure on what hardware you wanted, so I just included all the nubs/bolts/washers (20 total) needed to bolt the entire assembly together and on. Thanks! PMs returned as well!
fullwidthyotaon40s is offline
Old 03-15-2012, 10:20 AM
  #26
RMA
RMA's Avatar
what's up man. have you sent the door and rear skirt yet..I'm only a couple hours from you.payment sent last week..
RMA is offline
Old 03-15-2012, 12:46 PM
  #27
RMA
RMA's Avatar
sorry man .. got home and the package is here thanks alot ..
RMA is offline
Old 03-15-2012, 02:45 PM
  #28
pholife's Avatar
I will take the AC Control Panel ....does it work property...I mean does the knob move freely...lmk thank you
email = tor.parts at gmail.com
pholife is offline
Old 03-17-2012, 04:28 AM
  #29
Thank you very much for the Hubs, they look great, just need to clean them up a bit and order the spindle nut conversion kit and will be good to go, thanks again....
Old 03-18-2012, 05:16 PM
  #30
jd20phill's Avatar
still have the front grill? how much to 72023?
jd20phill is offline
Old 03-18-2012, 05:34 PM
  #31
streetlancer's Avatar
You still have the cluster?
streetlancer is offline
Old 03-18-2012, 06:42 PM
  #32
jbeezy22's Avatar
Do you have the a/c lines?
jbeezy22 is offline
Old 03-19-2012, 02:05 PM
  #33
pakman64's Avatar
I haven't herd back from you in a while, was wondering if I can still get the two sliding windows off of the cap. PM me with your address so I can send you the money.
pakman64 is offline
Old 03-26-2012, 10:28 AM
  #34
MattRX's Avatar
Need parts-46064
Hey Man, I would buy the rear interior panels. Mine have been cut to hell with a PO's speakers. Also I need sunvisors, manual shifter boot, gas door hinge, and center console top and hinges. Thanks in advance for your reply. I'm at 46064.
-Matt
MattRX is offline
Old 04-05-2012, 03:07 PM
  #35
islanderoffroad's Avatar
Did you sell the driver's side window/door lock switch?
islanderoffroad is offline
Old 04-17-2012, 11:32 AM
  #36
secondone's Avatar
I'm looking for the dash with vents and the rear side panels behind the seats if possible.
Thanks.
secondone is offline
Old 04-19-2012, 01:46 AM
  #37
dirron's Avatar
Do you still have the door panels? And how about the Window motors and lock actuators? Basically I want to convert my manual locks/windows to electric.. I'm in Sacramento, so I might be able to pick them up, unless you can ship (packaging is a pain, i know)..
dirron is offline
Old 04-19-2012, 03:25 PM
  #38
clok's Avatar
I need the rear window relay located behind drivers side rear panel . Let me know if you got it and how much shipped to 90278. Thanks.
clok is offline
Old 05-24-2012, 12:51 PM
  #39
Smeddy2's Avatar
Is the trim on the tailgate that says "Toyota" still good? My lock cylinder is froze with rust and my license plate lights are falling apart. I'd need a key to match. Also looking for a non-rusted out rear window channel. The part that the defrost hooks into and the regulators slide in that is attached to the bottom of the window. I'm in 64137.
Thanks!
Smeddy2 is offline
Old 05-28-2012, 10:41 PM
  #40
bend's Avatar
Alternator plug- It physically plugs into alternator. I need it with about 4" of wire
washer fluid res with sender- I really just need the sender. Has to have outlet nipple
ac hose bolts- I need the two bolts that screw the two ac hoses into the ac compressor
glove compartment- assuming it has both hinges intact
ac/heater face plate
cruise control bolts- two bolts that bolt the cc down in the engine bay
passenger side power window motor
Let me know
bend is offline
Quick Reply: '88 4runner part out (rolled) Santa Rosa, CA
