22re Manual Transmission - W56 out of 87 4Runner - $120
I no longer have a need for this transmission. It was pulled out of my 1987 Toyota 4Runner and shifted through the gears just fine. Reverse works too. The only issue was that first gear would pop out occasionally if you accelerate in first and then slow down in first. That would cause it to pop out to the neutral position.
I was able to get it to stay in first gear when needed in this situation by holding it into first gear, so just applying a little pressure to hold it in first. That seemed to work every time and it wouldn't pop out of gear.
Aside from the first gear issue it shifted through the gears just fine and never had any issues with it. It fits any 22re motor I believe, came from my 4Runner so it fits those as well as some pickups. Does not come with transfer case, just the transmission. I also have the shifter attached to it still.
I can deliver to the Vancouver/Portland area for gas $$ if needed. I should be able to get photos for those who want.
MMA_Alex
25
04-18-2017 05:07 AM
