***20lb CO2 tanks***
I sat down for a while with a rep at welding supply company this afternoon. Originally, I went in to price out cylinders just for me. After talking to the rep for a little while, he agreed to cut me a massive discount on a bulk order of CO2 tanks. Originally, I went in to ask about 10 and 15lb tanks. Unfortunately, they don't actively stock them. However, they do stock 20 lb tanks. And they end up being cheaper than a 10-15 lb tank because they keep them in bulk. To qualify for the lower price, we need to order at least 10.
I can offer these in 3 stages - bare, static and loaded
BARE:
20lb Aluminum C02 tank, filled. No regulator, hoses, etc. Just the tank and the gas as pictured, no regulator, hoses, or fittings - $140
STATIC:
20lb Aluminum CO2 tank, filled, 150PSI static (non-adjustable) regulator, fittings and 20' of hose. All you need is the tire chuck of your choice. - $195
w/ mounting bracket - $230
LOADED:
20LB Aluminum CO2 tank, filled, 0-200PSI adjustable regulator, fittings and 20' of hose, and mounting bracket. All you need is the tire chuck of your choice. - $340
For comparison, Off-Road Air sells their 20lb system with 200psi adjustable regulator, hose and bracket for $402.80. Power Tank sells their PT-20 Comp package with 200psi adjustable regulator, hose, and bracket for $519.95. That's a savings of $180!
If you are interested, please copy and paste the following in your reply to this thread and add your forum username name along with which package you want:
1. HaveBlue - Loaded
2.
3.
4.
5.
6.
7.
8.
9.
10.
Once we reach 10, I will contact each of you to collect payment.
If you have any questions, please feel free to PM me or e-mail me at HaveBlues4Runner@gmail.com
BARE:
STATIC:
LOADED:
2.
3.
4.
5.
6.
7.
8.
9.
10.
But that is a really good deal for a 20lb tank!
That is how i would do it, get them empty. You will have to get them filled later to use them anyways so it is not a big deal and it makes everything simpler. Plus the $15 to fill them is about the same as it will cost you to fill them someplace else.
If you live in Colorado, I can bring them to you filled with no shipping cost. Otherwise, they will be empty and shipping charges will apply (calculated on a case-by-case basis)
Boomer8404
09-17-2015 07:59 AM
saphirekosmos
06-22-2015 10:26 AM
