What would be a viable '90 pickup RWD rim replacement?
I have a 1990 pickup, rwd.
It currently has 14x6.5s on it...but one of the rims has a notch on the edge of the bead seat and it's apparently too big of a notch that I can't have new tires installed and balanced.
The bolt pattern is 5x4.5" (5x114.3mm), offset is 20mm and bore is 67.1mm.
Since the OEM spec rims do not exist anymore, are there any rims I could replace them with?
Could I get by with 15x7's paired with lower-profile tires and spacers if the offset doesn't match?
I'd hate to sell the truck because I can't find the most basic of parts.
Yes, go with 15s & spacers if needed.
FS[PacSouthWest]: 4 Alu rims $5 ea in the 91765
Punchy
9
03-04-2014 07:29 PM
lofreqjeff
08-10-2010 02:09 PM
