Old 04-21-2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
Print Wikipost
What PSI (pressure) are you running?
Old 09-24-2007, 12:58 PM
  #81
RunnerUp's Avatar
30 on my 285/75/16 terragrapplers, decent gas mileage and nice ride... wear is even as can be
Old 09-24-2007, 01:46 PM
  #82
X-AWDriver's Avatar
Originally Posted by skjos
32psi all around with 265/70/r17 BFGoodrich AT KO E-rated tires.
35psi is an abusive ride on an E-rated tire, 32psi is mucho better.
E load on a 4Runner is kinda harsh period. My Nittos are D and at anything over 35psi they start to get harsh.
Old 09-25-2007, 10:34 AM
  #83
skjos's Avatar
The E-rated tires were snuck on by the guys at Discount Tire, I didn't notice that they were E-rated until a buddie pointed it out much later.
I figured the new harshness in the ride was due to the lift I put on at the same time. After airing down to 32psi, the ride is now pretty good.
I've learned lesson; not only do you need to specify the brand and size, you also need to include the load rating.
My new rims are rated for 2,150, its a good thing my tires will handle 3,195. When my rims crumble at least my tires will still be good. =)
Old 09-25-2007, 11:09 AM
  #84
X-AWDriver's Avatar
Yep,when you look up TGs on the Discount site it automatically brings up the E load rated version and you actually have to look at the subset of Nittos to find the D load rated which there was also a considerable price diff too.
Old 09-09-2008, 02:16 PM
  #85
Jay351's Avatar
35psi for the road - Was running 40 but my tires didnt like it much.
Old 09-09-2008, 02:45 PM
  #86
Tacoclimber's Avatar
35 psi for mine. (285/75R16 BFG TA's.)
Old 09-09-2008, 04:36 PM
  #87
BigO's Avatar
I was running my BFG M/T completly flat until a few weeks ago when Obama told me to air them up. I now run them at ~32psi, and I am getting much better gas mileage now!
Thanks Mr. Obama!
Old 09-16-2008, 10:33 PM
  #88
ryantowry_81's Avatar
i run 4 on the trail and like 15 on the street, but i run 39.5x15 TSL bias so they are pretty stiff and it only sees the street once in a blue moon.
Old 10-15-2008, 06:54 PM
  #89
thisisnttomwyatt's Avatar
36 tsls at 10psi
Old 10-16-2008, 10:55 AM
  #90
racermp's Avatar
30, my ride gets bouncy on the freeway if it's over 30.
Old 10-16-2008, 03:35 PM
  #91
xcmountain80's Avatar
40 PSI with my 295 Nitto Terra's
Aaron
Old 10-16-2008, 05:31 PM
  #92
Yoda's Avatar
105 PSI on the company Firetruck
Old 11-13-2008, 09:01 AM
  #93
poorboyota26's Avatar
40psi on average 31 bfg AT's I get 2mpg better when I run 45 on the highway. I run 10-12 psi on the trail.
Old 12-04-2008, 09:15 AM
  #94
Vanman's Avatar
My tires call for a max of 50psi, so I usually run them at 45-47. I don't check them too often, but they seem to hold pretty well. Usually only have to add air every 4-5 months (that's how often I check the tires, WOW! That sounded bad...)
Old 12-14-2008, 11:59 PM
  #95
Squeebs's Avatar
40 in the front, 36 rear
Why are you guys running less air in the front? Thats where all the weight is...
Old 12-15-2008, 06:10 PM
  #96
Oh oh 45psi and with awesome fuel economy results. Yeah!
Aaron.
Old 01-01-2009, 12:27 PM
  #97
99SR5's Avatar
Originally Posted by Adam F
stock tires, 32psi as per door jamb sticker
yep. always suppose to run what it says on the door
Old 01-01-2009, 03:46 PM
  #98
rowdy235's Avatar
34psi Kingstar Radial H714's 185/65/14
Old 01-01-2009, 04:11 PM
  #99
toyota-erik's Avatar
8 psi front/7psi rear
Old 01-01-2009, 07:57 PM
  #100
Unless your door jam stickers don't match your tires!
Aaron
Quick Reply: What PSI (pressure) are you running?
