Old 03-30-2016, 03:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Tire Repair and Maintenance
Print Wikipost
Tire Size... PLEASE HELP!!! 265/75/16
Old 12-15-2012, 09:40 AM
jaxsage's Avatar
So I know this topic has been beaten to death but I still don't have a clear answer. I just got a 2003 4x4 trd tacoma. I need some new tread and I'm going with BFG AT's. Stock size on the truck is 265/70/16 Rugged trails. The BFG At's in 265/75/16 are $50 cheaper per tire compared to the 265/70/16!!! Will the 265/75/16's fit without rubbing????? I am not planning on lifting anytime soon due to lack of cash. These tires will be mounted on a 16 x 8 steel wheel with 4.5 backspacing. I am fine with the stock size tire (plus i like my mpg and speedo now) but if i can save $200 i will do it. Thanks for any input.
My second option would be to get the wheelers off road toyota steel wheels in a 15x 8 and put the 31/10.5/15's on. Much cheaper setup. Anyone have this setup?????
Old 12-15-2012, 10:49 AM
MudHippy's Avatar
http://www.tacomaworld.com/forum/tirecalc.php
I HIGHLY doubt that a tire 1" taller than stock is going to rub. You could probably run 33s(265/80/R16) or taller without issues.
Old 12-15-2012, 11:27 AM
jaxsage's Avatar
Yeah but this is on a stock truck with NO lift. Some people say the 75's rub and some don't. The stock rugged trails only have about a 1' clearance on the mud flaps and fenders. Don't care about the mud flaps but don't want to have to trim the fender flares.
Old 12-16-2012, 01:47 PM
MudHippy's Avatar
Then with a 1" taller tire you would still have a ½" of clearance. Unless you really meant 1' of clearance, then you'd still have 11½". Either way you should be fine right?
Old 12-16-2012, 07:15 PM
2big4arunner's Avatar
Here ya go, hope this helps
I believe you can run up to a 285.75r16 without major cutting. Info from the sight is as follows.
Very handy tool btw... putting it on my phone and home computer as shortcuts
I run 245/75r16 which are as follows
Now, if I pull some pricing for the tires it is as follows
265/70r16
Bfgoodrich AT KO - $212 plus shipping (d load rating) http://www.tirerack.com/tires/tires....omCompare1=yes
Goodyear Wrangler DuraTrac - N/a in this size
265/75r16
Bfgoodrich AT KO - $197 plus shipping (e load rating ) http://www.tirerack.com/tires/tires....omCompare1=yes
Goodyear Wrangler DuraTrac - $198 plus shipping (c load rating) http://www.tirerack.com/tires/tires....omCompare1=yes
245/75r16
Bfgoodrich AT KO - $202 plus shipping (e load rating) http://www.tirerack.com/tires/tires....omCompare1=yes
Goodyear Wrangler DuraTrac - $179 plus shipping (c load rating) http://www.tirerack.com/tires/tires....omCompare1=yes
So as you can see the 6 ply (more then enough for us SUV/Light truck types) in the goodyear duratrac (which is a wicked little option btw) is 20 bucks cheaper then the rest of the tires and looks Gnarlier.
Old 12-16-2012, 07:26 PM
Lawn Dart's Avatar
I followed everyone's advice on this forum and it was wrong. They said 265/75-16 on stock wheels wouldn't rub. It did and I had to buy a 1" suspension lift.
Old 12-16-2012, 07:45 PM
jaxsage's Avatar
That's what I'm afraid of. I think I'm sticking with stock size.
Old 12-16-2012, 09:12 PM
Go with the 245/75r16. More pressure per square inch yet less restriction traveling down the road. Technically the ESACT same size (slightly slightly smaller) and 20mm narrower. Cant go wrong and its cheaper then the 265/70r16
Old 03-17-2014, 02:18 PM
SC_Forester's Avatar
265/75r16
I know this is a little late but I run 265/75r16's on my stock 1998 Tacoma. I got a set of 16 inch stock 4runner wheels and put a set of BFG AT's on. I have a slight tire rub on the frame at full turn so I just try to keep from turning the wheel to full lock. It filled up the wheel well nice.
Attached Thumbnails Tire Size... PLEASE HELP!!! 265/75/16-truck1.jpg   Tire Size... PLEASE HELP!!! 265/75/16-truck3.jpg
firstgen88
10-07-2015 04:53 PM
Williamemslie
14
10-05-2015 09:28 AM
Scatterbrain
09-03-2015 06:46 PM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: Tire Size... PLEASE HELP!!! 265/75/16
