center caps on steel wheels
These are wheels on a base Tundra, want to see if I can put some kind of center caps on them. It looks like too tight of a fit for push throughs?? Maybe caps held on by lug nuts and cut metal tabs off if there are any, any suggestions? Thanks
It doesn't appear that those wheels were designed for a center cap of any kind. Maybe wheel covers? If your set on using them, you may have to have the center hole machined out a bit to accept a push through cap. Or use a dremel if you don't care about looks so much. They appear to be lug centric, so the lugs do all of the centering of the wheel, not the hub. So the center hole being a slight bit oversized here and there prob isn't a big deal. Just my thoughts...
06-01-2021 01:51 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
terminator
07-27-2015 07:13 PM
