33x12.50 baja claws on 92 4runner?
Old 04-09-2013, 01:36 PM
mrbcyota92's Avatar
I have a stock 1992 v6 4runner (automatic so it has 4.88 stock gearing) well it has a airbag lift in the rear but aside from that suspension is stock. My question is will I be able to fit these tires on my stock rims?
Old 04-09-2013, 02:22 PM
MaK92-4RnR's Avatar
just because it has the automatic, doesn't mean its 4.88 stock gearing. You need to check the vin.
you wont fit those tires without a lift. 33x10.50 R15s fit stock with minimal trimming
Old 04-09-2013, 02:27 PM
mrbcyota92's Avatar
Thanks for the reply, I will be doing a 2 inch body lift before attempting to fit them, but does anyone know if the stock rims will fit these tires? As far as checking the VIN is there anything easier then calling Toyota?
Old 04-09-2013, 02:29 PM
MaK92-4RnR's Avatar
2" body lift will work with the 33x12.50s.
stock rims will work. but you can get some 15x8 cragar soft 8s for pretty cheap and make it look a little better
Old 04-09-2013, 03:33 PM
michael1963's Avatar
There is lots of good links in this thread on gearing.
https://www.yotatech.com/forums/f116...osting-204178/
Old 04-09-2013, 04:14 PM
mrbcyota92's Avatar
My door sticker says "G254" , according to that I have 4.556 gearing I beleive
Old 04-09-2013, 04:30 PM
Yeah mine says the same thing. I have a 91 4Runner that I am running the same size of tire you are asking about and it has no issues. I also have a 3in BL on it.
Old 04-26-2013, 10:42 AM
mrbcyota92's Avatar
The 15 inch rims were to small, the tires were R17's (should of realized that before trying to fit them) anyways I managed to pickup a set of 17 inch american racing rims from a 2005 4runner, costed me 400 dollars, sanded them and painted them black. Just got them put on and I didnt even need to install the body lift, so ive decided to go with a 1 inch body lift instead . Right now they rub a little bit when the wheel is fully cranked nothing to worry about though. Im thinking of putting 1 or 2 inch wheel spacers, anyone have any opinions on wheel spacers?
mrbcyota92's Avatar
by the way i never did any trimming or torsion bar cranking.
Old 08-08-2013, 06:11 AM
kschiff's Avatar
I'm running 33" cooper sst mts under a stock lift on a 98 runner
Old 10-09-2013, 09:24 PM
nuttynu's Avatar
33 12.50s will fit with a lot of trimming. I gutted about 3" of my front bumper. They now clear... But have not been tested at driving,or off road yet.;
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 33x12.50 baja claws on 92 4runner?
