2nd gen 4runner with 4runner sport wheels
Old 02-10-2010, 06:55 AM
runnermedic's Avatar
hi friends!!!!
well i just want to know if there is someone using 4th gen 4runner wheels in a 2nd one?
recently i buy a set of 4runner sport edition wheels but some question and doubts still in the air like the need for wheel spacers,and the fitment of the wheel cap. those wheels look nice but i knew i was going to deal with the backspacing not a big problem,all wheels fit nice with out spacers the real problem is in the front wheels add hub is tooooo big to get the center cap in,so logic says a set of spacers will fix this,but the question is wich ones????? trying to get the exact measure needed i found that with a few washers i can clear them and fit the wheel cap but i realize that i need a caliper tool,one more tool to the list!!!
any advice????
Old 02-10-2010, 07:23 AM
TNRabbit's Avatar
You shouldn't have any problem fitting any Toyota 4x4 wheels with any other model:
Old 02-18-2010, 08:06 AM
new wheels fitted !!!
well finally the wheels are installed and all center caps too,
a few modifications to the front center caps and its done!!!
Attached Thumbnails 2nd gen 4runner with 4runner sport wheels-img_01512222.png
Old 11-20-2013, 10:47 AM
stevilknievil's Avatar
What to do
What did you need to do to get the wheel caps on the front wheels? About to pick up the same set from my brother who just upgraded...
Old 11-20-2013, 10:54 AM
Also...what size tires are these?
Old 11-20-2013, 03:12 PM
Tires 195/65 r17 only found in michelin and dumlop and to use tge front caps you need to remobe the internal guts of the cap also the locking wire, in the rig you need to remove the grease cap and use a 1/2 inch wheel spacer the front caps now dont have anyway to secure them so you have to glue them for life with urethane glue before installing the wheels thats all
Old 11-20-2013, 08:59 PM
That doesn't sounds too difficult. Do you know whether or not the center caps off the stock 95' wheels would work on the sport rims w/o modifications? I appreciate the info!
Old 11-20-2013, 11:06 PM
Nope they wont
Old 11-21-2013, 08:23 AM
Ok thanks again for the help. I'll post pics once I get them on. Attached is what it will kinda look like...just set the wheels next to my runner
Old 11-23-2013, 10:11 AM
Paul H.'s Avatar
I tried to fit some Tacoma Prerunner wheels on my 4runner and the fronts would not fit. 4wd and 2wd wheels are a bit different from my experience.
Old 11-27-2013, 03:49 PM
Well here it is
1" wheel spacers all around. Front center caps didn't have to be modified. 265/70's don't rub at all and didn't rub before the spacers either
Old 11-27-2013, 03:54 PM
More pics
More pics are attached. What do you guys think?
Old 11-27-2013, 03:56 PM
One more pic
I dunno why it isn't letting me post more then one pic at a time. Ipad maybe?
Old 11-27-2013, 04:31 PM
Youre right with 1 inch theres no need to mod the front caps, i used the 1/2 inch because i didnt like the wheels getting out the fenders
Looking good bro!!!!!
Old 12-02-2013, 10:46 AM
Sport wheels with spacers
Thanks man glad you like it!
Old 09-07-2015, 09:34 AM
really miss her!!!
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
skoti89
07-06-2015 07:45 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd gen 4runner with 4runner sport wheels
