Camping, Expedition, & Overlanding Gear Discussion pertaining to outfitting yourself with gear for the great outdoors
irab88's 1983 Coleman Sun Valley Build-Up Thread
Old 04-21-2013, 07:10 AM
  #441
JBurt's Avatar
interesting... I'm really curious to see how that turns out.
Old 06-10-2013, 07:51 AM
  #442
nemesis1637's Avatar
Tires?
Are these the tires you got? I have the exact same pop-up and need new tires for it:
https://www.etrailer.com/Tires-and-W...a/AM3H290.html
Old 06-10-2013, 08:33 AM
  #443
irab88's Avatar
yep. though if you flip your axle to be under the springs, you can get a slightly larger tire size
Old 06-18-2013, 11:54 AM
  #444
irab88's Avatar
bad news, guys.
well, not that bad. rather, an oversight. i went out to look at my trailer roof the other day, and found a lot of the side seams, where the skin meets the trim, to have pulled apart. when building the roof, i didn't account for expansion of the skin. the top seams are fine, but i can't say the same for the edges. so what i'm going to ave to do is cut slits on the sides, overlap a bit, and seal with the tar/foil tape. it should retain its water-rappelling abilities, but just won't look as neat. oh well, live and learn.
Old 06-18-2013, 10:32 PM
  #445
ChefYota4x4's Avatar
Sorry to hear, but it sounds like you haven't suffered any damage from rain or such inside? As you said, live and learn, indeed! You'll get it quick like!
Old 06-19-2013, 04:08 AM
  #446
irab88's Avatar
eh, i haven't opened it up yet. but since all the gaps are at the edge seams, there's no reason to assume water ingress. bugs, however, may have found a new set of condos
Old 08-08-2013, 04:13 AM
  #447
irab88's Avatar
all right; the roof is sealed up better. i took it over to "my" garage and popped it open a bit. i took care of the big splits in the roof, and fixed the wiring a bit (turned out to be a bad ground)
i have an upcoming trip to the beach later this month, so i went ahead and finished up a few things. first, the hitch was too low, especially with the truck loaded down at the same time. so i took another drop i had lying around and swapped out balls last night:
that should pick it up since i did the axle flip
the next thing was to finalize the plug situation. i wanted separate turn signals on my trailer, so i added a second plug (the 3 wire one) with ground, left turn, and right turn. the truck has the same thing, except the mixed stop/turn signals are just stop lights. it all works out well.
Old 08-08-2013, 10:24 AM
  #448
Nice, looking forward to pics of your trip. Hope it's a good'n!
Old 08-22-2013, 08:03 AM
  #449
irab88's Avatar
beach trip photos. not many, because my group couldn't make it, but a few.
getting a shorter drop hitch worked nicely; the trailer was damn-near level
and of course...
Old 08-22-2013, 08:35 AM
  #450
Ian, excellent pictures! Also, just as important to mention... Really nice work. I agree, it looks really sick be perfectly level like that... Which is actually better for everything in regards to wear... Nice work on that as well. Good to see you chilling there on the beach man..., any detailed pointers or should I say bullet points as far as your trip & the camper use? I thought it was really Kush!
Old 08-22-2013, 09:21 AM
  #451
irab88's Avatar
pointers? just a few:
-have somewhere you can go in the event of a strong storm. i had 2 strong thunder storms pass over, and had to spend one night at a friend's house. your tow vehicle will also work.
-if possible, put eye-bolts on either side to attach guy lines to. in strong winds, all the stress is put on the lift arms.
-in the summer, it's soooo niiiice to have working air conditioning. mine from ebay worked flawlessly, and made things so comfortable.
-spare tire; get one. i ran over a ratchet strap on the freeway and had to change out tires. having the spare saved my ass.
-an awning would have been nice, but probably caused a lot of problems in the storms.
-if the area isn't well lit, make sure your porch light works. i lit mine up (retrofitted with the leds) and it lit up the whole area.
-if possible, fold up your camper when it's not raining. that way, you won't have to dry it out when you get home.
anyway, that's my experience. rain ingress was never a factor, and the roof held up fine. i had a great time, even though i had to leave a day early (weather became cooler than normal)
Old 11-08-2013, 10:28 AM
  #452
JBurt's Avatar
If you don't mind me asking what did you use for your mattresses? I looked and saw you went to a fabric store but I was just curious.
Old 11-08-2013, 10:49 AM
  #453
Again, that thing is sexy! Lol
Old 11-12-2013, 03:49 AM
  #454
irab88's Avatar
yeah, it's just cushion foam. i don't know exactly what it is (my mom got it), but it's nice. with the thinner mattresses, use a firmer foam so you don't sink down to the boards
Old 11-07-2018, 04:33 AM
  #455
irab88's Avatar
Wow, it's been a while since I updated this thread...
I got the truck's engine swap done at the end of last year, and took the camper out once since then. It was a nice weekend trip.
The trailer is for sale. I'm moving, so this is the perfect time to sell it. I'd love to sell it to someone on the forum, as I know it'll get love (if only for parting out).
Old 11-07-2018, 05:47 AM
  #456
Fossilized
Staff
dropzone's Avatar
too bad you are selling it. i wish we still had ours, lots of good times
Old 11-07-2018, 06:16 AM
  #457
irab88's Avatar
I have a trailer... you wish you had a trailer...
Wanna drive 84 hours round-trip?
raptor510
08-19-2015 02:15 PM
58rennur4
08-04-2015 08:49 AM
SMOD
07-23-2015 10:29 PM
jgallo1
07-22-2015 04:21 AM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: irab88's 1983 Coleman Sun Valley Build-Up Thread
