Staging Area For Tech Article Submissions Got a tech article to submit? Post it here
88 22re weird oil leak cannot locate
Old 11-02-2012, 09:13 PM
89_Runner's Avatar
So here's some history. Blowen motor when purchased. So i ripped it out and put in a motor i had in the garage. It was a block loaded (crank, pistons ext.) Put on a newer head. New gaskets for everything. Get it back in the truck. Got it running. Now when its just sitting there running or with me hitting the throttle under the hood no leaks. But when i go on test drives it starts leaking like no other. It only leaks on the foward left hand side of the block. It seems to be around were the water tube connects to the front cover. But i know thats were coolant is. So i guess im wondering if the front cover might be cracked. Just trying to get an idea so i know were to start working on it. Thanks
89_Runner is offline
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
jakebarrett
07-10-2015 07:15 PM
87blyota
07-10-2015 04:31 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 88 22re weird oil leak cannot locate
