manifolds/headers?
manifolds/headers?
I have a 94 TPI model 350 in my toyota and the manifolds are cracked causing a horrible exhaust leak and killin the 02 sensors. I have searched and searched and cant find the same manifolds that are on the motor. Anybody else have a similar set up that can point me in the right direction as to which manifolds are correct.
Also did some searching on here and seen that flowtech midlenght headers might work, is this confirmed or what? I dont mind spending the money on them seeming they are around 100 bucks. but dont want to throw money around chasing possibilities
im not sure what a TPI model 350 is but i know north west off road makes headers for the small block chevy and fords maby others 2 im not sure but there custom for the toyotas hope this helps
it the newer gm 350, an LT model, the difference is the distributor is behind the water pump instead of on top behind intake manifold.
anyways i would look into block huger shorty headers but because every application is different when it comes to motor swaps you really just have to take some measurements of the space they go into then find a pair that will work the NWOR ones will not work for every application because they will not work with my sbf swap and there customer service is terrible and very difficult to get any useful info from.
Whatever you do, don't go w/ AA's, i've got them in mine, they cracked a few months after using them. Exhaust leaks like crazy!
i'm gonna go block huggers once i get the SAS done.
I didn't realize they won't work on a straight plug engine, so I have a leftover set if anyone's interested.
