Domestic Swaps Chevrolet, Ford, ect
I bought a 87 4runner with 4.3vortec TH350 swap already done...
Old 09-21-2012, 06:14 PM
87runner1207's Avatar
Originally Posted by james92toy
You have "gm CPI motor " made from 1992 to 95 . Allmost 200 hp stock .
Good motor but " spider injector " the fuel injector is prone to leaking when they get old . Easy to replace if bad , cost about $175 .
Same motor I have in my 92 4runner.
I would do a basic tune up first then check for a vacum leak , then leaky injector.
ok well i went ahead and just took the intake manifold off to make sure it was good... but i beleive it isn't the passenger side had a small puddles and the drivers side is black everywhere... this picture is after i tried cleaning it up... but as i was gunhoe on taking the intake off backwards of the directions i was givin haha i noticed a vaccum port under the butterfly that wasnt hooked up to anything. where would it need to be hooked up?
Attached Thumbnails I bought a 87 4runner with 4.3vortec TH350 swap already done...-4.3-intake.jpg
Old 09-21-2012, 06:15 PM
Thanks for the help guys
Old 09-21-2012, 08:06 PM
james92toy's Avatar
If there's puddles of gas in the intake you have a leaking injector. If you put a new injector in , also put the fuel line kit in it to .
Check out this link.
http://www.s10planet.com/forum/showthread.php?t=4342
On the driver side of the intake there should be a vacuum valve with a electrical conector . Your missing hoes from the vacuum port under the butterfly goes to it then keeps going to the charcoal canister.
Looks like this
http://www.oreillyauto.com/site/c/de...2211&ppt=C0018
And yes it need to be hooked up or plugged up. It would be a vacuum leak.
duckhead
170
11-13-2017 06:07 AM
TNRunner88
07-01-2015 08:00 PM
greenbuggy
06-28-2015 10:40 AM
infinityisfive
06-16-2015 06:51 PM
Gene
05-25-2002 02:39 PM
Quick Reply: I bought a 87 4runner with 4.3vortec TH350 swap already done...
