Diesel Swaps Diesel engines
Are you satisfied with you om617 swap
Old 12-03-2013, 10:31 AM
Cadin's Avatar
1992 FJ80 OM617 R151f
Swap was worth is for me, but most would find it underpowered for my application (Stock FJ80 in 31's).
I still have ~stock power, but I have 50% better fuel economy now. (11.9 mpg -> ~18mpg)
It couples sweetly to the R151f, and this would be an excellent combination in a 4Runner.
x2 on the intake manifold sludge... It took a lot of elbow grease and brake cleaner (well ventilated area!), to clean mine up. Don't forget to do something about that pesky EGR
(Perfect time to install an egt probe as well...it is sure comforting to have the feedback)
Also, what I've found, by talking with folks on the Merc forums that they run their Mercs at 3000 rpms all day. My truck actually purrs at this rpm... I often shift ~4000. What do you guys shift at?
I think ~2400rpm is max torque (and efficiency?); and ~4200 is max HP (~140 opened wide, w/o injector pump rebuild etc...)
Old 12-03-2013, 01:16 PM
Justinfordham's Avatar
I'm not real bright but would bigger pipe from the turbo not dramatically lower egt? That's what I was going to try when I swap mine in the up coming months
Old 12-18-2013, 07:54 AM
taylorf16's Avatar
Not really. The EGT probe measures the temperature of the gas going from the engine block, through the manifold, to the turbo. If you opened that up, you would have to custom build a turbo manifold, and the larger you went, the more turbo lag you would have.
Old 03-01-2020, 11:06 PM
wrenchtech's Avatar
I was on the diesel pump UK website recently. They are experts in upgrades for the Mercedes diesel, primarily the OM 606, but more recently the OM 617. Looks like some good stuff.
89drifttruck
7
04-09-2013 05:59 AM
f4stunna
Engine Swaps
37
12-13-2011 12:37 PM
eightnine
02-07-2011 04:35 PM
Krash
01-05-2006 04:06 PM
fierohink
14
04-11-2005 05:04 PM
Quick Reply: Are you satisfied with you om617 swap
