Diesel Swaps Diesel engines
PowerstrokeJoe's om617 Turbo Diesel swap/build in 1990 P/up
Old 10-21-2013, 08:40 PM
  #461
PowerstrokeJoe's Avatar
Thanks RamblinOn. My hope was this thread would help someone else out.
Beasty- I am not sure what you want to do for cooling. I am not sure with the w56 in the stock location if you could clear a mechanical fan. You may not need a drive shaft if you can leave the crossmember in the stock place. You can also use the stock alternator if you want. I didn't see a pilot bearing adapter on your list. Luke can get you one.
Old 11-16-2014, 08:48 PM
  #462
bigshrek's Avatar
Hey Joe,
just checking in and seeing how you still like your swap? I'm in the process of finishing my swap, had to put mine off for a while.
Thanks,
Carl.
Old 11-17-2014, 04:17 AM
  #463
dberwin's Avatar
617 swap in Cache Creek BC
I am running one in Canada. It is doing great. 8k last summer and a few bugs but all is well and doing a few things in the shop this winter. It drives good and perfect power for the toyota. Bit slow in fast highway driving but you are not in a race car. Daniel
TheBFA
02-15-2020 06:55 AM
buckz6319
08-05-2017 03:50 AM
primordialbeast117
12-19-2015 12:23 PM
scott90
10-04-2015 09:21 AM
voiddweller
09-28-2015 11:21 PM
Quick Reply: PowerstrokeJoe's om617 Turbo Diesel swap/build in 1990 P/up
