Diesel Swaps Diesel engines
Diesel for a T-100
Old 03-12-2009, 01:43 PM
yota_Pirate's Avatar
Cool Diesel for a T-100
I am looking to buy a T-100 but I want to put a diesel engine in it any ideas on what engines would work for this truck
Old 03-21-2009, 11:15 AM
Adam F's Avatar
Any engine you want. You just have to make it work.
Old 03-21-2009, 02:04 PM
Belize Off Road Team's Avatar
Any will fit, i recommend finding a state legal Toyota diesel from a LC or Pick-Up from the 70's or early 80's.
Old 04-09-2010, 07:19 PM
Ahbustae86's Avatar
Cummins 4bt.
Old 04-11-2010, 10:18 PM
LukeWilson's Avatar
I just picked up a TDI Passat to use as a parts car for my Pick Up swap. Paid $300 for the entire car and once the 1.9 engine is warmed up a little (chipped, injectors and a decent intercooler) it will easily put out 150 hp and 250 ft lbs. I am not sure what tranny is in your T100 but if it is a W56, several companies make adapter plate that will bolt it right up. Wiring isn't too bad either, the VW stuff is pretty self-contained. All you really need is keyed power the the ECU, glow plug power and power to the cooling fan. There are a few other small bit you need from the car like the potentiometer from the gas pedal and clutch and brake switches. There have been a couple well documented builds if you take a look around the forums. I just love the idea of getting more power and fuel mileage than my 22re that's coming out.
Luke
Old 04-12-2010, 08:43 PM
aviator's Avatar
There is a co. here that is swapping in Mercedes 300TD turbo diesels with some success... you could get a half cut toyota Hilux diesel from a place in Texas... or try a Hino diesel - Hino is toyota's heavy truck div....
The VW diesel might be a little small for your application.
Old 08-20-2010, 10:49 AM
T.U.F.F.'s Avatar
4BT CUmmins
RobotMoose
02-22-2020 07:44 AM
nvwiggins
13
06-16-2016 03:05 PM
presto30
Engine Swaps
12-10-2015 12:01 PM
Quick Reply: Diesel for a T-100
