Diesel Swaps Diesel engines
93 T100 conversion.
Old 08-02-2013, 10:23 PM
TackDriver's Avatar
93 T100 conversion.
I'm wanting to convert my t100 to a diesel. Right now I have a 3.0l in it which has no power at all with 235,xxx on it. I was thinking a VW turbo or a 4bt cummins but I think that would be a tight squeeze and a little much of a overkill. Needing some suggestions and info on difficulty.
Old 08-04-2013, 01:02 PM
draggin209's Avatar
I think the tdi might not have enough power to push a t100. A 4bt would fit an you'd probably have to beef up the frame a bit.
Old 08-04-2013, 02:52 PM
TackDriver's Avatar
Would a diesel out of a benz 300D have more power than the tdi? 4bt would take alot of fab work and i would probably have to beef up the entire drive line system
Old 08-11-2013, 08:54 AM
Vin4Runner's Avatar
From what i read the benz will only produce about 80hp and 125lb ft torque. The cummins would have more power stock. Check out the toyota 3L or 5L, both over 120 hp and more torque. Some parts may be easier to find or connect without to much custom work. Saw this in this other thread
https://www.yotatech.com/forums/f162...ersion-269535/
Old 08-11-2013, 08:04 PM
waltt's Avatar
Om617 turbo has 125hp stock and 170tq. the pump can b tuned to produce 145hp easily. I'm driving a 94runner with one now. it could have more power, still way better then 3vz it replaced. mines still stock. And thay have been built to over 400hp. those ones didn't last long. 200hp isn't supposed to be to hard to get. if ir interested check out peach parts. its a good Mercedes fourm.
Old 11-15-2013, 09:40 AM
TackDriver's Avatar
My buddies and I have been thinking since my old man is such a Ford fanatic with tons of ford truck parts and such laying around been thinking about throwing a 302 into it.
Old 11-16-2013, 09:59 AM
waltt's Avatar
Thay r heavy. a friend of mine who owns a shop said that jeep used a Toyota R series tranny behind the later 4.0 tj. thay r very good engines, probably the only thing off of a jeep that's worth using . lol
Old 11-20-2013, 09:51 PM
Zpd426's Avatar
Get your hands on a mini duramax
justdifferentials
14
06-11-2017 08:36 PM
stanz
10-30-2015 10:33 AM
tallsasquatch
09-20-2015 02:48 PM
mat
09-17-2015 11:18 PM
Tcsdef
09-07-2015 11:17 PM
Quick Reply: 93 T100 conversion.
