Diesel Swaps Diesel engines
88 4Runner 1kd-ftv swap (NEW) w/pics
Old 03-31-2012, 03:00 AM
  #61
RBX
RBX's Avatar
Thx man!
Old 04-01-2012, 09:26 AM
  #62
ChefYota4x4's Avatar
Hey, ....if it doesn't work out, you could always float one of these in there, right? hehehehe........
Just sayin, lol. JK, TOTALLY can't wait to see this moving forward!
Old 04-01-2012, 09:44 AM
  #63
RBX
RBX's Avatar
I can't wait to see it move forward either. I am going to go see a 1kdftv tomorrow and I can't wait.
Old 04-01-2012, 07:03 PM
  #64
aviator's Avatar
Take lots of pictures...
Old 04-02-2012, 09:10 AM
  #65
RBX
RBX's Avatar
Pics coming shortly. Visited a local boat shop. Wouldnt you know, they are the only US dealer of the marinized KD
Old 04-02-2012, 10:40 AM
  #66
Great news, RB!
  #67
...........Please? hehehehe. Just messin.... just anxious I guess!
Old 04-02-2012, 12:09 PM
  #68
RBX
RBX's Avatar
Marinized 1KD-FTV
Alright here are some pics, sorry for the cell phone shots, didn't realize how blurry they were till i got home to upload them.
This is the 200hp model, making torques in the 400ftlbs range. There are three flavors, 165hp, 180hp, and 200hp. The only difference is the ECU flash from NanniDiesel. I was also told that Toyota just gave NanniDiesel the go ahead for a new ECU tweak...wait for it....260hp/500+ftlbs!!! Same exact engine.
I was also told that in the next year and a half Toyota will be releasing diesels to the US(we'll see).
The tape measure is there for my reference of course.
This engine has an ECU that doesn't care about the VSS(this could be a solution when i try to install this beast.
yes 100amp alternator
nice oil filter adapter with a drain tube for catching spilt oil upon removal
Different oil pan option then on the auto version
Waste gated turbo, non variable vain. So ECU doesn't monitor turbo(not sure if this is good or bad)
Fuel Cooler, hooked to fresh water intake
Side showing fuel filter connection to fuel cooler
Old 04-02-2012, 12:30 PM
  #69
URrrrrrmph........... Sorry, I think I just threw up a lil in my mouth from excitement! hahaha....
WOW, 260HP???? That'd be nice.....
Far as the "for the US"..... I believe the Diesel Tundra is out this coming year, no? Not sure how they'd hide it after that, right? lol. "WE WANT OUR DEEEEEZL'S AND WE WANT EM NOW!!!!" lol.
Best wishes, KILL IT! lol
Old 04-02-2012, 01:55 PM
  #70
RBX
RBX's Avatar
Ive seen lots of rumors but no confirmation on the tundra. Seems the plan is to release the V8 D-4D 322hp, haven't seen anything on the 4cyl D-4D.
Now I'm looking at sourcing an engine from Europe. Mainly I find write-offs so I need to see if a dismantled would cut one apart for me.
Old 04-02-2012, 01:58 PM
  #71
JBurt's Avatar
So was this just for measurements or are you going to try and adapt a marine engine? I think the halfcut would still be the best but you can only work with what you can get.
edit: Nevermind. You beat me.
Old 04-02-2012, 02:08 PM
  #72
RBX
RBX's Avatar
Halfcut is preferred. But keep in mind It's the same engine found in the other parts of the world, minus water cooled manifolds (intake, turbo, exhaust, Trans, fuel).
Old 04-02-2012, 04:21 PM
  #73
irab88's Avatar
this was me most of the afternoon:
Code:
while (time<4:40pm) {
--refresh();
--lookfor(pics);
if you do end up using the marine diesel, you seriously need to keep it blue
Old 04-02-2012, 10:31 PM
  #74
aviator's Avatar
260/500? SWEET!... wonder if that ecu flash would work in a non marine engine?
I'm guessing it probably would for a manual tranny install... might be too many parameters different for a slushbox...
Engine looks good in blue...
Old 04-03-2012, 03:09 AM
  #75
RBX
RBX's Avatar
Mos def keep it blue.
The marine ecu is flashable, but not in the way to change it to higher up, sorry for the confusion. The marine ecu can be tweaked as I understand, bu for the higher bp range you need to purchase the ecu. I'm guessing it's a few $$.
Old 04-03-2012, 03:59 AM
  #76
xxxtreme22r's Avatar
Dang, that's a sweet looking engine. What are these Marine motors put into? DIOdn't even know they were made.
Oh and "Waste gated turbo, non variable vain. So ECU doesn't monitor turbo(not sure if this is good or bad)" , it still might, is this a MAP (Manifold Air Pressure) type engine or is it still AFM/MAF?
Old 04-03-2012, 04:06 AM
  #77
RBX
RBX's Avatar
^^^ good question. I don't know, it's a diesel... Cram as much air in each stroke as possible, then figure out fuel mix... I guess. I'm still learning and researching.
Old 04-03-2012, 04:08 AM
  #78
Yeah I don't know much about the diesels, in addition to my MAP comment the way I understand it, most things with a diesel are done via the EGT sensor. I want to say these things don't even have an 02 sensor to worry about. But I could be wrong.
Old 04-03-2012, 04:59 AM
  #79
RBX
RBX's Avatar
Many diesels do not have an egt sensor. That is really an aftermarket sensor addition when you are adding more boost, and intercooler tweaks from what I understand.
Old 04-03-2012, 07:43 AM
  #80
aviator's Avatar
What I meant was the "flashed" mariine ecu controlled engine could be used in a non-marine {truck} application. Sometimes the ecus are application specific due to sensor inputs being there or not...
These Marine diesels would be used in workboats/fishing vessles and the like... possibly as re-powers in pleasure boats.
Quick Reply: 88 4Runner 1kd-ftv swap (NEW) w/pics
