Diesel Swaps Diesel engines
88 4Runner 1kd-ftv swap (NEW) w/pics
Old 05-07-2018, 07:25 AM
  #381
irab88's Avatar
88 4Runner 1kd-ftv swap (NEW) w/pics-l7gkb4p.gif
Old 04-09-2019, 05:44 AM
  #382
RBX
RBX's Avatar
I have some updates coming, however, I am working on using a more stable image hosting service since free services could dissolve at any moment. I was using Flickr, and trying to move to Google Photos since I pay for storage, yet Google doesn't seem to allow me to link an image. I'm all ears if anyone has any suggestions.
Old 04-09-2019, 06:25 AM
  #383
irab88's Avatar
imgur is what I use. It's what reddit uses, is free, and can host original sizes. Plus, the URLs are short.
Old 04-09-2019, 06:35 AM
  #384
RBX
RBX's Avatar
Thanks, I have the app on my phone, I'll have to look into that further since I know Reddit isn't going away and imgur was developed by someoen at Reddit iiirc.
Old 04-09-2019, 09:26 AM
  #385
RBX
RBX's Avatar
1KD out of hibernation
Been a while and now time to get crackin!
Some updates...
ECU was sent to Diesel Toys in TX for an ECU tune. Deleted the EGR and Immobilizer as well as added their mild tune to give more power and more MPG. After running the engine using TechStream I determined injector two would be failing soon, so sent the Injectors off to Baileys Diesel Group in Australia. After speaking with Simon, he told me that the main bearings are not a concern (as I was going to replace the mains) in these engines, but to switch out the hard fuel lines due to the mileage. So, new injectors (Stage 1 15% more flow), valve cover gaskets kit, fuel hard lines and suction control valve for the injection pump.
Valve cover off, the black gets on everything, its worse then anti-seize.
88 4Runner 1kd-ftv swap (NEW) w/pics-ynlgset.jpg
Injectors getting sent out to Baileys Diesel Group, going Stage 1 which has a 15% higher flow for a future mild tune.
88 4Runner 1kd-ftv swap (NEW) w/pics-tunomui.jpg
Intake manifold nastiness. There is a butterfly valve on the circular cylinders, with about an 1/8" of soot and oil tacked onto it.
88 4Runner 1kd-ftv swap (NEW) w/pics-qak4n1v.jpg
To deal with the black death...
Made a parts washer out of some bits we had laying around UnHoly Motorsports.
88 4Runner 1kd-ftv swap (NEW) w/pics-eb0fgdr.jpg
First pass with the parts cleaner, that is soot in the sink, about an 1/8" thick. This is all due to the EGR, cancer to diesel engines.
88 4Runner 1kd-ftv swap (NEW) w/pics-2pu2gno.jpg
Engine back on engine stand for cleaning and maintenance. Will be rotating the engine to clean the intake ports on the head.
88 4Runner 1kd-ftv swap (NEW) w/pics-crox4gl.jpg
More to follow
Old 05-09-2019, 05:28 AM
  #386
RBX
RBX's Avatar
Did some cleaning on the head intake runners and welding the EGT bung into the exhaust manifold.
88 4Runner 1kd-ftv swap (NEW) w/pics-hziolqn.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-jpdv8j4.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-dpuiwgo.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-6y5unux.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-npzvi9m.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-mmx0jua.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-ozi6poe.jpg
Welding on the cast manifold for the EGT bung
88 4Runner 1kd-ftv swap (NEW) w/pics-ovdxvrw.jpg
88 4Runner 1kd-ftv swap (NEW) w/pics-seinsjg.jpg
Old 05-09-2019, 03:04 PM
  #387
irab88's Avatar
Just welded that to the cast iron? How well did that work? I assumed you kept it hot while you worked?
Old 05-09-2019, 04:07 PM
  #388
Melrose 4r's Avatar
What solvent did you use to remove the EGR gunk?
Old 05-10-2019, 05:11 AM
  #389
RBX
RBX's Avatar
Yep, used a MAP gas torch and had the heat(voltage) cranked on the welder. I never realized just how thick the manifolds are, now I see why many guys just NPT tap the manifold.
Old 05-10-2019, 05:14 AM
  #390
RBX
RBX's Avatar
I bought a gallon of Sea-Foam, worked really well after letting it soak. Many of the 1KDs I've seen getting an EGR cleaning seemed to be much dryer than what I had, most seem to flake and scrape out. However, My mess was a black gooey substance that needs to be agitated to get removed.
  #391
RBX
RBX's Avatar
deleted
Old 05-31-2019, 04:15 AM
  #392
RBX
RBX's Avatar
I'm having trouble figuring out where to put some updates, the build thread or the swap thread....
Anyhow, I am going to leave the engine specific stuff here, and update my build page with the install shenanigans.
The following users liked this post:
COMTB (08-12-2019)
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 88 4Runner 1kd-ftv swap (NEW) w/pics
