Diesel Swaps Diesel engines
1st gen 4runner 3vze OM616 swap
Old 10-02-2013, 10:57 AM
neetch's Avatar
Hi to all,
after trying really hard to get my 3vze running properly, it started to spit water and work on 4cyl or less when cold so i knew that the swap time came.
I know that OM617 is popular because of its power but since i really dont need so much hp, i will be satisfied with the OM616 i recently bought. Can you give me some advices what to check or change beside belts before i start to put it in. It has 240k km on it, comp is within norm, i was thinking only valve check, water pump replace and belt change.
I will be using Merc starter, ps pump an alternator i hope to keep on the stock position since i wont be using my ac compressor. I have a340h automatic transmission and i am not sure how it will work with this small diesel but i hope for the best.
Thank you in advance for any advices regarding my project. Once again, i know that 617 is better option but 616 is what i have got to work with
This is my 4runner in its working environment, i mostly use it for towing bikes and moving ramps and whatnot.
pics soon
Old 10-04-2013, 11:10 AM
ajy4490's Avatar
Interesting going with the OM616, I'll be interested to see how it goes. Yeah as you say power will be low (74hp I think), but then again those old W123 chassis are just about as heavy as your 4runner currently. Another nice thing about the 616 is that you should have plenty of room in front for the stock fan and not have to move the radiator at all. All that aside, I've heard OM617 turbos going for as little as $300 at scrap yards...
Old 11-12-2013, 11:12 AM
neetch's Avatar
hi everyone
just wanted to share few pictures with you, today ive stripped my 3vze and took it out along with tranny. here are few pics of the last moments of 3vze under the hood. byebye 3vze, you sputtering bastard
Old 11-21-2013, 11:11 AM
neetch's Avatar
little update on my swap.
first we've put om616 on the motorcycle lift, leveled it and started to prepare the adapter plate and all other things
as you can see, unlike on the om617, on om616 oil filter housing gets in the way for the adapter plate so i had to remove it, will get to it later
here is the distance plate for the flywheel
thanks to dmarsh4x4 for this tricky one haha
it will be easy to get the holes out of that one
and the last one for today with plate leveled up with the tranny, ive also made some punchmark tools and got the holes marked for tomorrows drilling etc.
i really get a lot of help from this forum and also from my friend teo4runner who recently finished his om617 swap in 2nd gen 4runner, thank you guys.
Old 11-24-2013, 11:41 AM
neetch's Avatar
a bit of progress
Old 11-25-2013, 12:59 PM
neetch's Avatar
today the engine went in for the first time
thats it for today, tomorrow i hope to solve thje oil pan clearance and also oil pump intake needs to be angeled a little bit
Old 11-27-2013, 10:58 AM
neetch's Avatar
bit more from today, engine mounts and oil filter distance with gaskets are done
Old 11-28-2013, 11:38 AM
neetch's Avatar
more from today
finished relocating the oil intake and the oil pan but sadly didnt take a photo of finished oil pan because i wanted to try if it fits asap i had to remove the steering suspension, maybe i will put it back later on other position
Old 01-11-2014, 10:33 AM
neetch's Avatar
oil filter housing along with toy pressure sensor and adapter mounted
3vze EFI wiring mess cleaned
Old 01-13-2014, 08:16 AM
neetch's Avatar
it is alive started from third, bleeding wasnt so hard as i have red. here is crap quality video of the first time my om616 came to life. it was struggling with ther rest of air but after some time got calm.
http://youtu.be/GwEQWx4atEM
Old 01-13-2014, 08:32 AM
neetch's Avatar
just realized there is no sound, ill take another one tmrw with some better camera :/
Old 01-16-2014, 02:56 AM
neetch's Avatar
finished mounting OM616 radiator, i had to remove fan so i guess ill be using something small electrical in the front. any of you have advice on choosing fan switch, auto (temp switch) or manual? i think ill use manual switch to avoid auto temp switch failure and problems with high temp.
Old 01-16-2014, 08:50 AM
waltt's Avatar
I use the manual switch it works good you just have to remember to turn it on When you're going under 35
Old 01-16-2014, 08:58 AM
waltt's Avatar
I was wondering how your automatic transmission is going to work without the ECU telling it what to do. I'm sure you already thought of this but I figured I'd ask Because I'm kinda curious. Nice work man
Old 01-16-2014, 12:11 PM
neetch's Avatar
first i will wire up switches to solenoids but i hope to get plc soon.
Old 01-18-2014, 06:13 AM
neetch's Avatar
went really productive today, got to wire up my temporary manual automatic transmission
the beta version of throttle cable holder
hooked cooling lines from the scrap pile of leftover tubes from 3vze and othera various mopeds/motorbikes
also i did short test ride an i am very happy with my swap, torque converter revs it a bit higher on the uphill but it is ok
Old 01-18-2014, 06:51 AM
neetch's Avatar
one more
Old 01-18-2014, 01:37 PM
Captain Jack's Avatar
Smile
Nice job. Really like the buildings you drove by. BEAUTIFUL!
Old 01-19-2014, 01:37 AM
neetch's Avatar
thanks.
the location is island Rab, Croatia, EU
Old 01-24-2014, 07:32 AM
neetch's Avatar
looks like my swap just went to "total tear down bodywork", guys who painted it before were really "tidy" which led to whole bunch of rusted areas
Quick Reply: 1st gen 4runner 3vze OM616 swap
