Diesel Swaps Diesel engines
1997 1.9L VW TDI into 1984 Extracab 4x4
Old 12-04-2011, 08:57 PM
TruckeeToy's Avatar
http://forums.tdiclub.com/showthread.php?t=304345
Old 12-05-2011, 08:55 AM
PowerstrokeJoe's Avatar
This is an interesting swap. I'm assuming you are using the 1z since it is a 97. What are you going to do about the wiring, or you going to convert it back to all mechanical. I know the TRi's can be pretty wiring intensive. I am not super familiar with the 1z as we don't see too many of them around here. Most of them and ALH's and we have a BRM as well.
Old 12-05-2011, 01:07 PM
TDITOY's Avatar
cool build, Im getting ready to do the same swap with the same truck!
Old 12-05-2011, 07:01 PM
TruckeeToy's Avatar
Powerstrokejoe, I did use the 1Z and kept the electronic controls. It's three wires, so, while the wiring isn't super easy (some would say it is), I'd say it's not super difficult. TDIClub is loaded with good info.
TDITOY, you've obviously done your homework, too. Oil pan clearance is easy, esp. with a slight lift. The solid axle... is one of the best trucks ever built. The G52 trans can handle the torque (R151 is of course better). Parts are cheap. The 1Z is solid and pre-smog. Stock, the truck moves right along and idles over anything you point it at in 4lo. Hope my thread helps. Just email me with any questions.
Old 12-06-2011, 03:24 AM
RBX
RBX's Avatar
I've been following your handy work on TDIclub.
Old 12-06-2011, 08:37 PM
TDITOY's Avatar
I have an ALH out of a 2001 beetle, looking for a 1z. Still debating on using electronics or not, and I plan on running a r151. I am also putting in a doubler with 5.29's, linking the front and 63's in the rear on 40in iroks
06-01-2021 01:51 PM
mussy01
12-13-2016 08:20 PM
SharpStick
08-29-2015 12:59 PM
defrag4
07-31-2015 10:50 AM
kcaudill
07-20-2015 12:06 PM
Quick Reply: 1997 1.9L VW TDI into 1984 Extracab 4x4
