All Other Toyota Swaps I4, I6, Lexus V8
My Lexus V8 into 2nd Gen 4Runner conversion.
Old 01-17-2011, 04:15 PM
  #161
pushin glass's Avatar
Originally Posted by LifterCatcher
This is awesome and I have just spent about five minutes looking on the net for the
1uzfe and holy smokes you can pick them up super cheap with around 65k miles insane!!!
Very cool post. I'm thinking of doing a similar swap. Where are you finding them for cheap?
Old 01-17-2011, 05:18 PM
  #162
Hardstripe's Avatar
you can get em for 500 all day long on ebay. I would recommend contacting a jdm importer directly to save even more cash by circumventing the middle man (ebay)
Old 08-02-2011, 09:33 PM
  #163
SK4RNR's Avatar
Very nice rig!
Old 01-06-2012, 10:52 AM
  #164
rocktoy86's Avatar
Loking for user: MSE
DOes anyone know if this user is still around? They were last posting on here in 2010, and saying that they were building parts for the Lexus V8 Swap, and I need to get hold of them. If anyone can help me out, I would sure appreciate it! Thanks!
TC
Old 01-14-2012, 04:10 PM
  #165
Dr Crawl's Avatar
Incredible runner, looks like it came that way from the factory.
Old 01-16-2012, 02:51 AM
  #166
jbuck07's Avatar
Ok. I know this thread is a little old, but could somebody break down exactly what i need to get to do this swap in my 1993 Hilux Surf? Am i gonna need an electric fan and a different radiator because of clearance issues? Im tryin to gather everything i need and figure out a cost. I would very much like to do this swap especially since the 1uz-fe's are everywhere over here in Japan....
Old 01-17-2012, 10:24 AM
  #167
Hardstripe's Avatar
Rocktoy: what are you looking for, i might be able to help
Old 01-18-2012, 05:55 PM
  #168
Asgard's Avatar
Engine mounts, bellhousing, modified headers or aftermarket ones. a new modified sump is needed if you don't want to do a body lift. I use the stock ECU, Stock diesel Surf Radiator (recored).
Best fan I've found is a spal http://www.spalusa.com/store/main.as...&item=30100401
One of the few that fits perfect and doesn't give any cooling problems thrashing it in an Aussie summer.
Old 01-18-2012, 08:58 PM
  #169
jbuck07's Avatar
sweet. is there anywhere in particular to get the headers? what about the engine mounts and the belhousing kit? i already have a 3inch body lift so i dont think i need a modified sump. my surf is gasoline so, will a diesel radiator fit in mine?
Old 01-19-2012, 01:43 PM
  #170
Asgard's Avatar
Headers depend on what clutch release setup you use. If you wish to use the stock slave cylinder on the outside of the box with a clutch fork, it doesn't leave you with much room on the side for headers. I've started using Howe Hydraulic release bearings for my conversions, they cost less than $150 from summit and save a HEAP of time with header fab down the track. ( plus its one less thing for me to tear off under the car )
I've used a petrol surf radiator before, worked fine, I just had it recored to make sure it was up to the task.
With a 3" body life you won't need a sump change.
I'll post pics of engine mounts in a bit if you like and the part number of the Howe Hydraulic release bearing.
Old 01-20-2012, 01:59 AM
  #171
jbuck07's Avatar
Ok. The hydraulic release bearing, is that for manual trans? Mine is an automatic. Is there any company out there that sells the custom engine mounts or do i have to fab them up myself?
Old 02-08-2012, 04:38 PM
  #172
Backcountry's Avatar
That's awesome!!!
Old 02-22-2012, 03:49 PM
  #173
SK4RNR's Avatar
Wire harness
What did you do for the wiring harness? Is there a company that makes a harness for the conversion?
Old 03-10-2015, 04:50 PM
  #174
Bikeveloce's Avatar
I know this is an old thread, but is there anyway you can post the photos again? The original ones are not loading..
Old 07-18-2015, 02:21 PM
  #175
instantninja's Avatar
if anyone is looking for stock parts to do a manual swap, heres a site that sells 100 series land cruiser bellhousings, flywheel and clutch parts.
http://shop.cruiserparts.net/index.p...&cPath=44_3184
clok
11-19-2015 01:09 PM
sanctfy
09-15-2015 02:52 PM
rusty
04-01-2004 07:13 PM
Gringo
16
02-23-2004 04:18 PM
Los Gatos?
10
12-10-2003 01:41 PM
Quick Reply: My Lexus V8 into 2nd Gen 4Runner conversion.
