4RunnerGuys 4Runner 1uz swap
Finally desided to go head with the project.
is there anyone that sells the motor mounts for this project?
im also keeping the manual 5speed, and all be getting into detail on wiring harness for the people that feel brave enought to do it there own.
All so cause no one has a detailed wiring diagram.
will be posting a vid of what happend to my 3.slow tomorrow
4runnerguy, whenever I needed help with wiring, I consulted the following FSM:
1990 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34006966...0.1995.SIL.rar
OR
http://www.ncttora.com/fsm/1990-1995....1990.1995.zip
It has both wiring and mechanical section. The wiring folder has all PDFs which are color coded so you can exactly which wire is what. Other than those, I also consult my chilton manual which wiring section too.
Another Link: http://www.snjschmidt.com/wiring/
For ECU Pin out for 1991 4Runner 3VZE, download the above FSM and look into the section:
Engine->MFI System--ECM
Here is the 1993 Pickup ECM Pinout hosted online (this might be bit different than yours): http://personal.utulsa.edu/~nathan-b...ne/44engin.pdf
Best thing would be if you have wiring section of 1991 3VZE, but I think 1990 would be your best bet for now. Hope this helps and good luck!
Im curious what happened to your 3.0 .. you gotta post that video
PS. Some links were retrieved from: https://www.yotatech.com/forums/f128...-years-156128/
OR
UPDATE finally
got the motor and tranny mounted
Then i had to modify them a bit
This how my bell housing looks like after its all mounted up
now i got to get started on the wiring, manifolds and slave braket
Looking good man .. some clearer pics would be a lot better though
were you able to figure out those diagrams ? if i left out any let me know .
good luck man ..
good luck man ..
The harness your using is it from an ls 400 or sc 400 .. is the plug attached to the same harness that goes to the battery or are you pulling it towards the battery...the plug looks like its the oxygen sensor plug.
its been a wild but i got back to fixing the runner.
right now i am having a problem that the motor starts & runs but dies 1 to 2 seconds after?
