All Other Toyota Swaps I4, I6, Lexus V8
3RZ Info please
Old 02-12-2013, 04:22 AM
redbayredneck's Avatar
I wish some yotatechers lived close enough to help with a swap like that.
nobody around here knows how to do a motor swap unless it involves a Chevy small block. lol
Old 04-16-2013, 06:48 AM
87blackbeauty's Avatar
Originally Posted by BigMike
Oh man that looks like so much fun I just wish I could that every day.
BigMike
I'd probably say that... hahaha
Old 06-13-2013, 01:11 AM
wanab4x4's Avatar
i am currently doing this swap into a 89 2wd hilux with a 04 motor .. my question is . if i used a 04 dash with wiring wouldnt it plug right up to the dash harness/engine harness plugs next to ECM?
Old 06-13-2013, 07:09 AM
Yes. Other than that, your lighting is just about the only original wiring you'd be using. Are you trying to use all underhood wiring from the 04 including the fuse box and all? If so, the engine and driveability factor will be plug and play after you adapt the dash into it. I'm ready to do this swap, but I'm waiting until I can get a complete truck to swap from. Which is an issue you may or may not run into depending on if you're using the truck that your engine came out of. I don't know enough about those trucks, but I'm sure there are differences between models and... Stuff...
Old 06-13-2013, 09:55 AM
  #25
BigMike's Avatar
One issue you'll run into is that the Tacoma and Hilux fuel gauges are on opposite sides of the cluster, so I believe if you use a Hilux fuel sender, the Tacoma gauge will read "E" when the tank itself is full.
This happened when I swapped a 2003 3RZ into a 1984 Hilux. The scenario was opposite in that I used the Tacoma sender in the tank but kept the original Hilux instrumentation. The Hilux fuel gauge read "E" when the tank was full and "F" when the tank was empty. Our crude solution? Took a sharpie and blocked the lower portion of the "E" sign so that it appears as "F", and used white-out to paint on a lower section to the "F" sign so that it appears as "E". The gauge simply ran opposite of everything else! I never drove the truck at night but I assume both lettering would appear as "F" with the dash lights on!
If you use the Tacoma fuel sender then of course this won't be an issue.
BigMike
Old 06-13-2013, 09:31 PM
  #26
wanab4x4's Avatar
WELL IM GOING TO PICK UP THE DASH AND THE CLUSTER TOMARROW . GETTING IT FOR $160 LIKE NEW CONDITION WITH THE WIRING .. SHOULD I GET THE BODY HARNESS ALSO? I BELIEVE IT INCLUDES THE WIRING FOR THE o2 SENSORS . CAUSE I HAVENT SEEN ANY ON THE ENGINE HARNESS . OR CAN I JUST WIRE THEM INTO THE ECU?
YES THATS A GOOD IDEA IM NOT TO WORRIED ABOUT THE GAUGE AS LONG AS IT WORKS..
ALSO HAS ANYONE ELSE DONE THE 2WD 89 SWAP? .. CAUSE ITS TRICKY COMPAIRED TO 4WD .. THE CROSSMEMEBER HITS THE T100 OIL PAN SO DOES THE STEERING ..
HERES A PIC OF IT IN THE truck NOW
Old 06-17-2013, 08:36 PM
  #27
wanab4x4's Avatar
so i picked up the dash and harness and fuse box off the 04 so now i got all the plugs in the ecu and the whole dash harness .. and it fits right in with slight modification . my question is so now i have almost everything off a 04 tacoma all i need to do is power the fuse box and the starter wiring hooked up and it should run ?
Old 06-18-2013, 03:48 AM
  #28
R.DesJardin's Avatar
That's basically how I did it. Complete harness and connect it to everywhere it plugs and connect the fuse panel to power. Fired right up.
Old 06-18-2013, 12:13 PM
  #29
wanab4x4's Avatar
did u use the engine fuse box for the swap or just the under dash?
Old 06-19-2013, 07:03 AM
  #30
I used 100% of complete Tacoma harness including the gauge cluster, I also got the Taco wiper motor and made an adapter plate. The only connections I had to modify were front turn signals and washer pump.
Wish I would have grabbed the entire dash unit itseld and swapped it in. Maybe on the next one.
Old 06-24-2013, 01:32 AM
  #31
wanab4x4's Avatar
well no problem is . .i got a 5 speed engine wireing harness and ecu .. and a Automatic tranny dash and dash cluster and engine fuse box .. and i cant find the wires for the clutch start .cancel .. cause the dash wiring harness is from a auto so im assuming the wires run into the motor harness then down to the tranny? .. and the engine harness is from a 5 speed so it should have been on the dash harness... but i know that the small black with white stripe on starter harness 4 prong plug starts when 12v jumped so i find the 2nd pole on the ignition in start position wire .. connect them . and should work no problem ..
Old 08-16-2013, 08:40 PM
  #32
Sloth21's Avatar
So I found a 3rz on craigslist. has 106xxx and the guy wants $1000. What should I pay for this?
Old 08-17-2013, 02:26 AM
  #33
Fossilized
Staff
dropzone's Avatar
it all depends on the market IMO. if you can get the wiring harness and ECU and the engine is in good shape then i would think it is a fair price.
guys around my area say they find them for $500...if I find them it seems like they are $1200-1500
Old 08-19-2013, 09:31 AM
  #34
BigMike's Avatar
x2 This has been my experience as well.
Old 11-11-2013, 04:16 PM
  #35
kornhuskerwizard's Avatar
That pic is funny.wiring is for robots
TheBFA
02-15-2020 06:55 AM
91yotapup
3.4 Swaps
03-05-2019 10:41 AM
buckz6319
08-05-2017 03:50 AM
White Stripe
10-06-2015 10:47 AM
dirk89
10-01-2015 05:15 PM
Quick Reply: 3RZ Info please
