All Other Toyota Swaps I4, I6, Lexus V8
1uzfe swap in my future?
Old 07-11-2011, 10:42 PM
88runnasr5's Avatar
Alright I have read a coue of rma swaps and I am dumbfounded..
Alright I was set on doing a 5vz swap with a sc, but am really thinking a 1uz is better, I wanna know what exactly there is to doing the swap? I have a complete gutted 88 runner that had the 3.0 pulled that and all wires for it, so I have a clean canvas to paint, could I use the donor cars whole motor chassis wiring system? Not using the 3.0 gas tank going to run a custom fuel cell and run new lines for everything. I want to run a 5speed with dual cases, besides all the obvious fab work, how can I do it?
Old 07-12-2011, 05:36 AM
toyminator2000's Avatar
Not trying to be rude but you need to just do lots of reading. If you have specific questions, I and the rest of us that have completed this swap would be more than happy to answer them but general questions will only confuse you.
As for the question about the wiring. There is some of the chassis harness that you will need but there is about 5 times the amount of wiring in the Lexus than there is in the 4Runner and 90% of it doesn't get used. All of the plug changes occur at where they connect to the 1uz engine computer and a few at the alternator.
Old 07-12-2011, 02:51 PM
88runnasr5's Avatar
Well the only real question I wanna know is, how do I keep my manual? What all is needed?
Old 07-12-2011, 03:57 PM
Custom Bellhousing or Bellhousing adapter.
http://cgi.ebay.com/ebaymotors/1uz-1...Q5fAccessories
Then you can get a flywheel and clutch from the same place, get a 3.0 flywheel modified to fit or have somewhere custom make one.
Old 07-12-2011, 06:57 PM
88runnasr5's Avatar
I read somewhere a 3.4 flywheel would be better? Or does it really matter?
Old 07-14-2011, 06:28 PM
SHAGGY21's Avatar
im running a 3.0 flywheel. the only diff in the 3.4 and 3.0 is i do belige half an inch. as the 3.4 has a 10 inch clutch and the 3.0 has a 9.5 i do belive. i got my bell housing from ks racing.
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
edoyle12
11
03-20-2017 02:26 AM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: 1uzfe swap in my future?
