All Other Toyota Swaps I4, I6, Lexus V8
1uz swap in the works.
Old 04-19-2011, 09:28 AM
  #221
birdduck's Avatar
hey guys sorry for being MIA for a wile, between work/wife/kid/life been a little busy..
so some updates runner still gets driven every day, put cclose to 10k on it already
fixed my check enigne light(maf sensor) it stays off now yay! i also fixed my roof rack its about 2 inches off the roof now..
For the most part i have just been getting the chassy up to par, new lower ball joints(toyota oem) new front rotors, outer cv boot... would like to make a piece of pipe to replaced my frankin lower radiator hose just need to get the ball rollin. warm weather is almost here and i want to be busy
another update: started on a second swap! not for me but my friends 87 runner.. sweet rig SAS on 37's. suprising how much master the swap comes together when you have done it before! and the fact its in a shop not my driveway.....
Old 04-19-2011, 09:33 AM
  #222
birdduck's Avatar
85toyman...
okay looking threw your sig, you will be on easy street making yours fit wether your using a ls400 engine or sc, the oil filter fitting? this i just used a shorter filter and solved that issue. no body lift and no hood clearance issues either.
for the most part the lower you get on MY swap the closer the engine gets to the chassy. i had to remove the lug on the crossover bar for my steering damper or it would hit the oil pan. there is only about a 1/4" between it and the bar(oil pan vs steering)
good luck once you get started trust me you will be very happy when your done
Old 04-20-2011, 11:22 PM
  #223
85toyman's Avatar
Do you got any pics of the oil pan clearance. With my pan sitting on the cross over bar and taking a profile shot you can see about 1/3 of the intake throttle body opening. I removed the pan to sit it down in there and get it situated where I want it. I will modify the pan if I have to to get this thing in without a body lift.
If you got some more shots of the engine bay as well? Always like more of those.
Old 01-13-2012, 06:31 PM
  #224
alltracman78's Avatar
Bump, so I can find this in the morning.
Old 01-22-2012, 11:24 AM
  #225
SHAGGY21's Avatar
hey birdduck you wtill got your runner.?
Old 04-30-2012, 03:21 PM
  #226
birdduck's Avatar
runner still running strong and driven every day.. it needs some knock sensors to get back to 100% but other than that its great even got my isc working perfectly
Old 04-30-2012, 04:57 PM
  #227
birdduck's Avatar
85toyman, I have about a 1/4 inch in the lowest spot for steering clearance. There is no steering dampener at this time because the mounting point would hit the oil pan, so I cut it off. I have since swapped to 4:10's to help with freeway drive-ability.. decreased the crawl factor but made dd much more pleasant.
Old 09-19-2012, 06:00 PM
  #228
Dreidel's Avatar
ok so how did you get your check engine light to stay off while useing the manual trans that seems to be the common thing between all these swaps is the check engine light stays on all the time cause its not getting feedback from the auto trans im looking for info for what i want to do
Old 09-20-2012, 05:54 AM
  #229
birdduck's Avatar
The auto tans will not throw a code when disconnected, at least for my model year. The light was on for other sensors witch have since been repaired.
Old 09-20-2012, 06:20 PM
  #230
Dreidel's Avatar
Ohhh ok thank you
Old 11-15-2013, 02:45 PM
  #231
birdduck's Avatar
hey guys, long time since i last posted.. so i figured your all deserve a little engine pron
enjoy
coreyedwards7611
01-16-2016 06:38 PM
sanctfy
09-15-2015 02:52 PM
RaginAsian91
08-23-2015 10:27 AM
Steven.m.paulk
07-24-2015 01:44 PM
MTLroadierunner
07-20-2015 03:07 PM
Quick Reply: 1uz swap in the works.
