All Other Toyota Swaps I4, I6, Lexus V8
1uz swap into 90 pickup
Old 07-16-2010, 10:37 AM
  #81
birdduck's Avatar
i will go check if mine will pull out, i am pretty sure its not suposed to.
Old 07-16-2010, 10:42 AM
  #82
birdduck's Avatar
well looking at the a y exploded veiw, there looks like there is a retaining clip between
the planatery gears and one of the clutchpacks.. now time to go yank..? ha
Old 07-16-2010, 10:45 AM
  #83
highrideTOY's Avatar
so not funny. so there goes the other half of my freaking weekend. FU**!!!!!!!!!!!!!!
can u send me a link to the exploded view of the tranny?
Old 07-16-2010, 10:47 AM
  #84
birdduck's Avatar
yeah no go, like i thought. there is deff a clip in there holding the tail shaft. the hammer was a realy bad idea, the main reason is that inside the trans are brass shims, like a bearing on a rod, these are there to keep clearance and act as a bearing at the same time, you could have damaged some of them in the process of angry hamering.
maybe enven damaged the case.
Old 07-16-2010, 10:51 AM
  #85
well i couldn't find any other way to get the coupler on the tranny. it wouldn't slide on at all. guess i'm lookin for a tundra tranny now. I'll try to fix this tranny first but i doubt its fixable.
Old 07-16-2010, 11:20 AM
  #86
birdduck's Avatar
i have an extra one. its well sittin in the back of my truck. next time if it fits tight toss the coupler in the oven for a little about 10 minuts then put it on.
Old 07-16-2010, 11:44 AM
  #87
We'll see if i need a new tranny. I hope not. I gotta put the new headers on my tundra then put the manifolds on the 1uz and do a test fit. then i'll tear apart the tranny. if i need any parts for the tranny I'll send u a pm this weekend.
Old 07-16-2010, 12:16 PM
  #88
toyminator2000's Avatar
I had heard from the inchworm guy that sometimes on the Lexus tranny the output splines have to be sanded down a bit to fit the coupler on. I don't recall having to do this on mine though.
I think birdduck is correct. You broke the output retainer clip. Look on Ebay for a factory service manual for an A340 series tranny. I had one for the Lexus a340e but I loaned it out and never got it back. I'm afraid of them too but I'll take apart anything if there is a detailed manual on how to do it.
I'd take it apart. At this point what do you have to lose? Look for Cebby's thread. Its old and he hasn't done anything for a long time on his swap but he did have some detailed info on tranny disassembly. Good luck!
Old 07-16-2010, 12:31 PM
  #89
birdduck's Avatar
the picture i have is from alldata and it sucks wouldn't do just for dissassembly or reassembly
Old 07-19-2010, 01:36 PM
  #90
sorry it has been raining here a lot. I can't get any work done when it rains cuz i dont have a shop. lol
I do need to know where i can get the pins for the plug bird duck sent me? the plug goes into the ecu
Old 07-19-2010, 01:48 PM
  #91
birdduck's Avatar
you can use some from the other plugs, some of the wires your not using just unpin it from the plug and put it that there e11 plug..just make sure you leave plenty of wire after the pin so you can solder it together.. i have quite a few extras from mine so i a sure you will too.
Old 07-19-2010, 01:52 PM
  #92
aight I'll do that when i get time this weekend.
Old 08-02-2010, 04:27 PM
  #93
sorry guys. no progress lately. been too hot to do anything. 100+ degrees outside and 60% humidity. you can't stay outside more then thirty minutes til you're exhausted.
Old 08-02-2010, 06:34 PM
  #94
wslytoy's Avatar
105* today... I went outside to tinker on the 4Runner after dark, it was still too hot. I've got a lot to do to that damn thing, but I just can't work in that heat, it'll kill you.
Old 08-09-2010, 05:30 PM
  #95
ok been having issues gettin the manifolds off the tundra. anyone have any tips.
I've use an air gun at 100 psi and it won't even budge.
Old 08-10-2010, 01:25 AM
  #96
I can't believe an impact didn't have the torque to break the stud.
Kind of depends on if you care about the Tundra block. If you don't, get a 1/2 ratchet and about a 3 foot piece of pipe. It will either break loose or break the stud. Either way it comes off.
If you do care about the block try and heat the nut with a propane torch first.
Old 08-10-2010, 05:05 AM
  #97
birdduck's Avatar
get some pb blaster, spray all the bolts on the head and on the flanges... let it soak for a few hours, then go drive your tundra around for about 15-20 minuts.. this will allow the metal to get hot and the pb to penetrate the bolts, then try your impact again.
and if that doesn't work call cuck norris to come break them loose...
Old 08-10-2010, 05:39 AM
  #98
ok the tundra is my DD. so I'm not gonna break it lol. guess I'll have to try the pb blaster this weekend. will wd-40 work? also, are they flamable? may try spray the bolts after i heat them up.
Old 08-10-2010, 05:42 AM
  #99
oh and also forgot. I'm having issues gettin the radiator to fit, so i'm thinkin i may do what someone else(can't remember who?) did and cut the front cross brace and put in some angle iron as support. that way, i can push the radiator forward an inch or 1.5 inches. I'll also be fixing my transmission problem this weekend( I HOPE!).
Old 08-10-2010, 07:43 AM
  #100
birdduck's Avatar
you can spray the pb on it when its hot thats fine, just don't spray it into an open flame..
no you can eat dw40 if you wanted to.. pb blaster will melt a styrafoam cup...(i don't recomend eating wd40) PB is some knraly stuff don't get it in your eyes!
i am trying to use the factory rad in the factory spot, i have plenty of clearance to do so
but i am going to have to modify the radiator inlet to get the hose to clear the passenger
cam/dizzy cover.
Quick Reply: 1uz swap into 90 pickup
